automatic year change script
brizzicomunicazione
brizzicomunicazione posted this 05 January 2018
HTML- I would like to report what I think is an error generated during the integration of a script. At the foot of the page I entered the current year date, using a simple script:
1988 - <script type
type
type type
HTML- I would like to report what I think is an error generated during the integration of a script. At the foot of the page I entered the current year date, using a simple script: 1988 - &lt;script type type type type
Support Team posted this 09 January 2018
Are you using the CMS Code control for the script? If yes and it does not work, provide a script code here. Use the CTRL+K combination to highlight the code so it won't be executed.
Hi, Are you using the CMS Code control for the script? If yes and it does not work, provide a script code here. Use the CTRL+K combination to highlight the code so it won't be executed. Sincerely, Hella
brizzicomunicazione
brizzicomunicazione posted this 09 January 2018
Hi Hella,
I do not use any CMS control, but only the script in the html section; see script in the attached image
Then, I do not understand how / where I should use the control + k combination
Walt.
> Hi, > > Are you using the CMS Code control for the script? If yes and it does not work, provide a script code here. Use the CTRL+K combination to highlight the code so it won't be executed. > > Sincerely, > Hella Hi Hella, I do not use any CMS control, but only the script in the html section; see script in the attached image Then, I do not understand how / where I should use the control + k combination Thank you, Walt.
thfischbach
thfischbach posted this 10 January 2018
The easiest way is to use a CMS-Code control. Insert short PHP-Code like this:
<?php $actualyear=date("Y")
echo "copyright 2008 - $actualyear";
and everything will be fine. :)
The easiest way is to use a CMS-Code control. Insert short PHP-Code like this: <?php $actualyear=date("Y") echo "copyright 2008 - $actualyear"; ?> and everything will be fine. :)
brizzicomunicazione
brizzicomunicazione posted this 10 January 2018
