Them not working during Installation on Wordpress 4.9.1
vin64
vin64 posted this 07 January 2018
I can try to load the WP Theme many times, getting different error each time, once, sytes.css was missing, another time jseon file was missing. I recreated the ZIp file 5 times already with different names get the same errors, I'm using Hostgator for Hosting... IS THEMLER compatible with WordPress 4.9.1
I have not used themler in a while, but there used to be a Themler Icon within WordPress and I could edit the site there, Now all I get is a Themler Core. Is this normal?
Thanks In Advance
I can try to load the WP Theme many times, getting different error each time, once, sytes.css was missing, another time jseon file was missing. I recreated the ZIp file 5 times already with different names get the same errors, I'm using Hostgator for Hosting... IS THEMLER compatible with WordPress 4.9.1 I have not used themler in a while, but there used to be a Themler Icon within WordPress and I could edit the site there, Now all I get is a Themler Core. Is this normal? Thanks In Advance
Support Team posted this 09 January 2018
Please make sure you have checked the "Include Themler for customizing this theme" option on export. Let us know if the issue is still present.
Hello, Please make sure you have checked the "Include Themler for customizing this theme" option on export. Let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
L33onaardo
L33onaardo posted this 15 January 2018
I have same problem, since i updated WP to 4.9.1, and themler forced me to update today.
Can't edit anything inside themler plugin and this show up^ when i try open themler plugin.
Tried many times with diffrent exports names, nothing helped.
update: not working in chrome and firefox.
I have same problem, *since i updated WP to 4.9.1, and themler forced me to update today*. **Can't edit anything inside themler plugin** and this show up^ when i try open themler plugin. Tried many times with diffrent exports names, nothing helped. update: not working in chrome and firefox. [1]: https://ibb.co/eGLF2R [2]: https://ibb.co/eGLF2R
Support Team posted this 15 January 2018
I've installed fresh WordPress 4.9.1 and installed Themler theme. Themler works ok on my side. I can open theme, edit it and save without any problems.
It would be helpful to access the problem website. If you have public website which demonstrates the issue please create new Private topic and provide the access to the admin panel.
Hello, I've installed fresh WordPress 4.9.1 and installed Themler theme. Themler works ok on my side. I can open theme, edit it and save without any problems. It would be helpful to access the problem website. If you have public website which demonstrates the issue please create new Private topic and provide the access to the admin panel. Thank you, Olivia
