Menù item (article) as post instead page
loppini
loppini posted this 12 January 2018
i have a strange problem...
In a new Joomla website if I create a new menù item (singe article) the theme (created with themler) assign it the "Post Template" instead (as usual) the "Page Template"...
What's happen?
Hello, i have a strange problem... In a new Joomla website if I create a new menù item (singe article) the theme (created with themler) assign it the "Post Template" instead (as usual) the "Page Template"... What's happen?
Support Team posted this 16 January 2018
The difference is in the metadata. Post Template uses Joomla Single Article Layout too because there are no separate Post and Page content types in Joomla. The difference is that Page Template does not contain any article metadata like Author, Published Date, Hits, Category, etc.
Once metadata is disabled for the article from Joomla back-end, the article will have Page Template styling. If at least one article metadata icon is enabled, the article will use Post Template.
You may wish to look at the comparison here:
https://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes
Hello, The difference is in the metadata. Post Template uses Joomla Single Article Layout too because there are no separate Post and Page content types in Joomla. The difference is that Page Template does not contain any article metadata like Author, Published Date, Hits, Category, etc. Once metadata is disabled for the article from Joomla back-end, the article will have Page Template styling. If at least one article metadata icon is enabled, the article will use Post Template. You may wish to look at the comparison here: https://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes Sincerely, Nettie, BillionDigital Team
loppini
loppini posted this 18 January 2018
Ok, perfect, I understand.
Thank you!
Ok, perfect, I understand. Thank you!
Support Team posted this 18 January 2018
