Restore themes
Hospedagem de Sites
Hospedagem de Sites posted this 5 days ago
Friends, I had a problem with my HD that stopped working and I lost everything I had created with Themler. However, several themes are already on customer sites. Do I have to import themes from websites to re-edit them on Themler? Thank you ;-)
Support Team posted this yesterday
If you had exported themes with "Include Themler for customizing the theme" option enabled previously, then the theme can be opened in Themler using Themler option in CMS admin. Then you may export the theme from File tab >> Export as Zip and import it in Themler desktop or edit the theme right there, on your website.
Hello, If you had exported themes with "Include Themler for customizing the theme" option enabled previously, then the theme can be opened in Themler using Themler option in CMS admin. Then you may export the theme from File tab >> Export as Zip and import it in Themler desktop or edit the theme right there, on your website. Sincerely, Nettie, BillionDigital Team
