Contact Form 7 styling odd
lavisbre
lavisbre posted this 16 January 2018
enter image description here
Hi Im trying to change the color from pinky red to blue. I do not seem to be able to in contact form.
This must be built into my themlar?
Where do i go to change this color please
![enter image description here][1] [1]: https://image.ibb.co/c4Rt7R/form_color_of_text.png Hi Im trying to change the color from pinky red to blue. I do not seem to be able to in contact form. This must be built into my themlar? Where do i go to change this color please
Support Team posted this 16 January 2018
Please provide a link to the page where we could see the issue.
Hi, Please provide a link to the page where we could see the issue. Sincerely, Hella
lavisbre
lavisbre posted this 17 January 2018
https://seo-inbound-marketing.com/contact-us/
Support Team posted this 17 January 2018
The label color is red because the form is wrapped into the <code> tags. Please check the form configuration under the CF7 settings. If you remove this wrapping the text color will be black (inherited from section text color).
Hi, The label color is red because the form is wrapped into the `<code>` tags. Please check the form configuration under the CF7 settings. If you remove this wrapping the text color will be black (inherited from section text color). Thank you, Olivia
lavisbre
lavisbre posted this 18 January 2018
no I dont see any code to change color ;-(
It is defult going to a rubbish color and no settings to change it in contact 7 forms.
I belive its the template i made in themlar, can you point me in the direction is might be please
no I dont see any code to change color ;-( It is defult going to a rubbish color and no settings to change it in contact 7 forms. I belive its the template i made in themlar, can you point me in the direction is might be please
Support Team posted this 22 January 2018
It is not a theme. The form is wrapped into<code> tags. The text inside these tags has own formatting including color. Please check the CF7 form builder and remove extra empty spaces and characters. Or insert the form shortcode into the page content again. You have two code blocks: one is empty and one with form inside. They create small pink squares above the form that you can see on the page.
Hi, It is not a theme. The form is wrapped into`<code>` tags. The text inside these tags has own formatting including color. Please check the CF7 form builder and remove extra empty spaces and characters. Or insert the form shortcode into the page content again. You have two code blocks: one is empty and one with form inside. They create small pink squares above the form that you can see on the page. Thank you, Olivia
