Development focus to drupal
cm
cm posted this 18 January 2018
I and many more want that you put more focus on Drupal development.
Want Drupal8 themes and sections to http://templates.themler.io
What improvements you other need and want?
I and many more want that you put more focus on Drupal development. Want Drupal8 themes and sections to http://templates.themler.io What improvements you other need and want?
cm
cm posted this 23 January 2018
  1. BUG !!!
    Some icons vies in site like some characters, not their logos.
  2. BUG !!!
    When you tro to change picture on section. Same error comes if you browse file from local computer or from billionphotos clipboard.
  3. When you add section, sections own picture is visible in theme edit mode, but it dont show on page.
Fix these soon.
1. BUG !!! Some icons vies in site like some characters, not their logos. !someicons-drupal8-theme.png! 2. BUG !!! When you tro to change picture on section. Same error comes if you browse file from local computer or from billionphotos clipboard. !picture-change-themler-drupal8-2018-01-2.png! 3. When you add section, sections own picture is visible in theme edit mode, but it dont show on page. Fix these soon.
cm
If you change active other than thembler theme, you cant edit content / look theme settings if you dont unistall thembler module,
Support Team posted this 24 January 2018
Did you check directory permissions?
http://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version#permissions
The 403 error means that there is not enough permissions to access the resource and load image into the theme folder.
Are these Themler icons or third-party icons?
Could you please try to SAVE theme instead of PUBLISH. Does the issue continue?
Hello, Did you check directory permissions? http://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version#permissions The 403 error means that there is not enough permissions to access the resource and load image into the theme folder. > Some icons vies in site like some characters, not their logos. Are these Themler icons or third-party icons? Could you please try to SAVE theme instead of PUBLISH. Does the issue continue? Thank you, Olivia
cm
cm posted this 24 January 2018
All themler themes has 755 and all sub drirectories and files also.
cm
cm posted this 11 February 2018
Tryed to edit theme, cant do nothing.
400 bad request
OS: Linux vps289668.ovh.net 2.6.32-696.20.1.el6.x86_64 #1 SMP Fri Jan 26 17:51:45 UTC 2018 x86_64 E_WARNING: file_get_contents(libraries/mmenu/dist/jquery.mmenu.all.js): failed to open stream: No such file or directory /home/asiakastuki/cm.asiakastuki.info/core/modules/locale/locale.module 1134 Callstack: -> file_get_contents('libraries/...') -> _locale_parse_js_file('libraries/...') -> locale_js_translate(array(98) { ... }) -> locale_js_alter(array(99) { ... }, Drupal\Core\Asset\AttachedAssets(...) { ... }, NULL) -> Drupal\Core\Extension\ModuleHandler::alter('js', array(99) { ... }, Drupal\Core\Asset\AttachedAssets(...) { ... }) -> Drupal\Core\Asset\AssetResolver::getJsAssets(Drupal\Core\Asset\AttachedAssets(...) { ... }, false) -> Drupal\Core\Render\HtmlResponseAttachmentsProcessor::processAssetLibraries(Drupal\Core\Asset\AttachedAssets(...) { ... }, array(4) { ... }) -> Drupal\Core\Render\HtmlResponseAttachmentsProcessor::processAttachments(Drupal\Core\Render\HtmlResponse(...) { ... }) -> Drupal\Core\EventSubscriber\HtmlResponseSubscriber::onRespond(Symfony\Component\HttpKernel\Event\FilterResponseEvent(...) { ... }, 'kernel.res...', Drupal\Component\EventDispatcher\ContainerAwareEventDispatcher(...) { ... }) -> Drupal\Component\EventDispatcher\ContainerAwareEventDispatcher::dispatch('kernel.res...', Symfony\Component\HttpKernel\Event\FilterResponseEvent(...) { ... }) -> Symfony\Component\HttpKernel\HttpKernel::filterResponse(Drupal\Core\Render\HtmlResponse(...) { ... }, Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
Tryed to edit theme, cant do nothing. 400 bad request OS: Linux vps289668.ovh.net 2.6.32-696.20.1.el6.x86_64 #1 SMP Fri Jan 26 17:51:45 UTC 2018 x86_64 E_WARNING: file_get_contents(libraries/mmenu/dist/jquery.mmenu.all.js): failed to open stream: No such file or directory /home/asiakastuki/cm.asiakastuki.info/core/modules/locale/locale.module 1134 Callstack: -> file_get_contents('libraries/...') -> _locale_parse_js_file('libraries/...') -> locale_js_translate(array(98) { ... }) -> locale_js_alter(array(99) { ... }, Drupal\Core\Asset\AttachedAssets(...) { ... }, NULL) -> Drupal\Core\Extension\ModuleHandler::alter('js', array(99) { ... }, Drupal\Core\Asset\AttachedAssets(...) { ... }) -> Drupal\Core\Asset\AssetResolver::getJsAssets(Drupal\Core\Asset\AttachedAssets(...) { ... }, false) -> Drupal\Core\Render\HtmlResponseAttachmentsProcessor::processAssetLibraries(Drupal\Core\Asset\AttachedAssets(...) { ... }, array(4) { ... }) -> Drupal\Core\Render\HtmlResponseAttachmentsProcessor::processAttachments(Drupal\Core\Render\HtmlResponse(...) { ... }) -> Drupal\Core\EventSubscriber\HtmlResponseSubscriber::onRespond(Symfony\Component\HttpKernel\Event\FilterResponseEvent(...) { ... }, 'kernel.res...', Drupal\Component\EventDispatcher\ContainerAwareEventDispatcher(...) { ... }) -> Drupal\Component\EventDispatcher\ContainerAwareEventDispatcher::dispatch('kernel.res...', Symfony\Component\HttpKernel\Event\FilterResponseEvent(...) { ... }) -> Symfony\Component\HttpKernel\HttpKernel::filterResponse(Drupal\Core\Render\HtmlResponse(...) { ... }, Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
