Menu horizontal item activo not show indicated
elviro.valencia
elviro.valencia posted this 24 January 2018
Buenos días,
The horizontal menu in the web work fine.
When navigating to another item, it also works well, but the item home is still fixed permanently, instead of the item where it has been accessed, the same happens when accessing any other items.
I request help to solve this issue.
Greetings. Elviro
Buenos días, The horizontal menu in the web work fine. When navigating to another item, it also works well, but the item home is still fixed permanently, instead of the item where it has been accessed, the same happens when accessing any other items. I request help to solve this issue. Greetings. Elviro
Support Team posted this 24 January 2018
Please disable Menu module caching under the Joomla >> Module Manager >> menu module settings.
If caching is disabled please check the menu module base item. The base item field value should be "current".
Hi, Please disable Menu module caching under the Joomla >> Module Manager >> menu module settings. If caching is disabled please check the menu module base item. The base item field value should be "current". Thank you, Olivia
elviro.valencia
Good afternoon,
Following your instructions I have solved the problem.
Many thanks. Elviro
Good afternoon, Following your instructions I have solved the problem. Many thanks. Elviro
Nice to hear that it helped. Feel free to contact us in any other occasion.
Hi, Nice to hear that it helped. Feel free to contact us in any other occasion. Sincerely, Hella
elviro.valencia
Many thanks again. Elviro
