add_to_cart_fragments error in Wordpress Woocommerce
len
len posted this 24 January 2018
I am seeing the following in the Wordpress error_log file:
The "add_to_cart_fragments" hook uses out of date data structures and function is deprecated since version 3.2.6. Replace with woocommerce_add_to_cart_fragments.
I am sure this is due to the Themler theme.
Is there a fix for this please?
LenW
I am seeing the following in the Wordpress error_log file: The "add_to_cart_fragments" hook uses out of date data structures and function is deprecated since version 3.2.6. Replace with woocommerce_add_to_cart_fragments. I am sure this is due to the Themler theme. Is there a fix for this please? Thanks LenW
9 Comments
Support Team posted this 24 January 2018
Hello Len,
Does it cause any issues with the theme or website functionality?
Hello Len, Does it cause any issues with the theme or website functionality? Sincerely, Nettie, BillionDigital Team
len
len posted this 25 January 2018
If there are errors being written to the error log that must be slowing the website down, it cannot be good.
LenW
If there are errors being written to the error log that must be slowing the website down, it cannot be good. LenW
Support Team posted this 25 January 2018
Hi Len,
Does the same error occur when you activate a default WP theme (e.g. 2017)?
Ivan
Hi Len, Does the same error occur when you activate a default WP theme (e.g. 2017)? Thanks, Ivan
len
len posted this 26 January 2018
Ivan
I don't want to activate a default theme as this happens on an established woocommerce site, and it will mess up widgets areas.
This is on the Woo support thread on worpress.org:
https://wordpress.org/support/topic/add_to_cart_fragments-hook-out-of-date/
It confirms that the active theme is the issue.
LenW
Ivan I don't want to activate a default theme as this happens on an established woocommerce site, and it will mess up widgets areas. This is on the Woo support thread on worpress.org: https://wordpress.org/support/topic/add_to_cart_fragments-hook-out-of-date/ It confirms that the active theme is the issue. LenW
Support Team posted this 28 January 2018
Exactly what Themler version are you using? The version can be seen on the address bar when you start Themler.
Our developers already fixed similar compatibility issues some time ago. The most recent update should include this fix too.
Hi, Exactly what Themler version are you using? The version can be seen on the address bar when you start Themler. Our developers already fixed similar compatibility issues some time ago. The most recent update should include this fix too. Thank you, Olivia
len
len posted this 30 January 2018
The Themler desktop version with the Woocommerce theme loaded is v.435, and its not offering any update.
In Wordpress, the theme version says: Version: 1.0.526.
I have just regenerated aa new zip export from the desktop Themler, and it was at this version before so has not changed.
I have cleared out the W3TC cache.
I have deleted the wordpress error_log.
Wordpress then creates a new file with:
[30-Jan-2018 15:35:52 UTC] The The "add_to_cart_fragments" hook uses out of date data structures and function is deprecated since version 3.2.6. Replace with woocommerce_add_to_cart_fragments.
I have now worked out that clicking the add to basket button on a product detail page causes a new line in the error_log to be written.
LenW
LenW
Olivia The Themler desktop version with the Woocommerce theme loaded is v.435, and its not offering any update. In Wordpress, the theme version says: Version: 1.0.526. I have just regenerated aa new zip export from the desktop Themler, and it was at this version before so has not changed. I have cleared out the W3TC cache. I have deleted the wordpress error_log. Wordpress then creates a new file with: [30-Jan-2018 15:35:52 UTC] The The "add_to_cart_fragments" hook uses out of date data structures and function is deprecated since version 3.2.6. Replace with woocommerce_add_to_cart_fragments. I have now worked out that clicking the add to basket button on a product detail page causes a new line in the error_log to be written. LenW LenW
Support Team posted this 31 January 2018
Please try the most recent Beta update. Beta updates can be enabled under your Profile >> "Get Beta updates".
Hi, Please try the most recent Beta update. Beta updates can be enabled under your Profile >> "Get Beta updates". Thank you, Olivia
len
len posted this 06 March 2018
As Themler is loading, the URL that shows in the address bar is:
themler_846147007
Is this the version number?
When I access a theme, the help about is v.432, I thought that is the version number.
Just updated the theme to v.441
The add_cart message is now gone, instead I am getting:
[06-Mar-2018 20:41:49 UTC] The WC_Cart::get_remove_url function is deprecated since version 3.3. Replace with wc_get_cart_remove_url.
LenW
Nettie As Themler is loading, the URL that shows in the address bar is: themler_846147007 Is this the version number? When I access a theme, the help about is v.432, I thought that is the version number. Just updated the theme to v.441 The add_cart message is now gone, instead I am getting: [06-Mar-2018 20:41:49 UTC] The WC_Cart::get_remove_url function is deprecated since version 3.3. Replace with wc_get_cart_remove_url. LenW
Support Team posted this 07 March 2018
Our developers have fixed this issue in the current internal Themler version.
The permanent fix will be available with the next Themler update.
As a temporary workaround you may disable warnings using define('WP_DEBUG', false); in wp-config.php file.
Ivan
Hi, Our developers have fixed this issue in the current internal Themler version. The permanent fix will be available with the next Themler update. As a temporary workaround you may disable warnings using `define('WP_DEBUG', false);` in **wp-config.php** file. Please let us know if you have any further questions. Thanks, Ivan
