Slider not Responsive in mobile
petra
petra posted this 25 January 2018
I have read all the threads on responsive slider and I have tried the 100% width and auto Height but it just doesn't want to work it is asif the image themself stays big, I have looked where to resize the images themselves but can't see how or where to do it.
How do I make the slider work on mobile?
Hi I have read all the threads on responsive slider and I have tried the 100% width and auto Height but it just doesn't want to work it is asif the image themself stays big, I have looked where to resize the images themselves but can't see how or where to do it. How do I make the slider work on mobile?
10 Comments
Support Team posted this 25 January 2018
Please attach your theme exported with the content and editor included. And let us know on what page you have the slider.
Hi, Please attach your theme exported with the content and editor included. And let us know on what page you have the slider. Sincerely, Hella
petra
Will do, but can we make the topic private then?
I've made this topic private.
Hi, I've made this topic private. Thank you, Olivia
petra
petra posted this 27 January 2018
Here is the login details:
The slider is on the home page
Hi Here is the login details: The slider is on the home page
Support Team posted this 29 January 2018
Open the Slider control options on the top ribbon and for each slide under the Image drop-down set the size to cover or any other desired size under the responsive options.
Hi, Open the Slider control options on the top ribbon and for each slide under the Image drop-down set the size to `cover` or any other desired size under the responsive options. Sincerely, Hella
petra
petra posted this 29 January 2018
Hi Hella
Thank you so much it worked stunning!
If you remove my username and password in my one post, please make my post public again, I'm sure it will help others also.
Hi Hella Thank you so much it worked stunning! If you remove my username and password in my one post, please make my post public again, I'm sure it will help others also.
Thanks, I have removed the login details and case is now public again.
Hi, Thanks, I have removed the login details and case is now public again. Sincerely, Hella
Carlos
Carlos posted this 21 February 2018
I have followed the steps mentioned above, each slide has cover size but when I open on mobile the image on slider gets cut, I mean it doesn't reduce the image making it responsive.
This is the site: http://automotrizsa.com/
Hi, I have followed the steps mentioned above, each slide has cover size but when I open on mobile the image on slider gets cut, I mean it doesn't reduce the image making it responsive. This is the site: http://automotrizsa.com/ Thanks Regards
Support Team posted this 22 February 2018
Sorry, I can't access your site, gives the time out error.
Hi, Sorry, I can't access your site, gives the time out error. Sincerely, Hella
petra
petra posted this 22 February 2018
You have to go to mobile view and set the screen size there. So each screen will have their own size.
Hi You have to go to mobile view and set the screen size there. So each screen will have their own size.
