Help a beginner - Adding a Static block to left hand column in Magento 2?
lilypoter214
lilypoter214 posted this 29 January 2018
I have had a website Magento designed by a developer, now I want to create my first new page.
I have created a 2 columns page and have the copy and images sorted for the main part of the page.
So, I want to add one of the existing static blocks onto the left hand column, I just know where I need to enter the code (Layout update xml) but no idea what the code should be, can anyone assist please.
The identifier for the static block is left-img-static
Thank you in advance.
Hi, I have had a website Magento designed by a developer, now I want to create my first new page. I have created a 2 columns page and have the copy and images sorted for the main part of the page. So, I want to add one of the existing static blocks onto the left hand column, I just know where I need to enter the code (Layout update xml) but no idea what the code should be, can anyone assist please. The identifier for the static block is left-img-static Thank you in advance. Regards
doumekisaoryan
Is Solution
doumekisaoryan posted this 29 January 2018
Hi @Lilypoterbss,
Maybe this information can help you:
<reference name>
<block type="cms/block" name="your.1st.block.name" before="-">
    <action method="setBlockId">
        <block_id>your_1st_block_id</block_id>
    </action>
</block>
<block type="cms/block" name="your.2nd.block.name" after="-">
        <block_id>your_2nd_block_id</block_id>
    </action>
</block>
Or you can contact our team of experts to receive 24/7 support with these technical issues at: http://bssgeek.com/services/#maintenance-support
Hi @Lilypoterbss, Maybe this information can help you: &lt;reference name&gt; <block type="cms/block" name="your.1st.block.name" before="-"> <action method="setBlockId"> <block_id>your_1st_block_id</block_id> </action> </block> <block type="cms/block" name="your.2nd.block.name" after="-"> <action method="setBlockId"> <block_id>your_2nd_block_id</block_id> </action> </block> Or you can contact our team of experts to receive 24/7 support with these technical issues at: [http://bssgeek.com/services/#maintenance-support][1] Regards, [1]: http://bssgeek.com/services/#maintenance-support
lilypoter214
Thank you very much for your help, it's work fine. Your website Bssgeek is very helpful, we maybe become partners in a few days.
Best regards,
Thank you very much for your help, it's work fine. Your website [Bssgeek][1] is very helpful, we maybe become partners in a few days. Best regards, [1]: http://bssgeek.com/services/
