Js broken in Backend Magento 2
paulhudson.050785
paulhudson.050785 posted this 01 February 2018
After enable merge Js in Magento 2 Backend: Store/Configuration/Advanced/Developer and save config, I can't click any menu buttons in backend. I think that Js is broken and I can't go to Merge Js config and disable it again. Does anyone know how to solve this problem?
lilypoter214
Is Solution
lilypoter214 posted this 01 February 2018
You go to database of Magento 2 site, run this SQL command:
SELECT * FROM core_config_data WHERE path LIKE '%dev%'
Change 'dev/js/merge_files' to '0'
Then run deploy theme command with SSH to see if it works?
Otherwise, you could click here to know the easiest & most optimal approach to this issue
You go to database of Magento 2 site, run this SQL command: SELECT * FROM `core_config_data` WHERE `path` LIKE '%dev%' Change 'dev/js/merge_files' to '0' Then run deploy theme command with SSH to see if it works? Otherwise, you could [click here][1] to know the easiest & most optimal approach to this issue [1]: http://bssgeek.com/services/
Support Team posted this 01 February 2018
Please note, that we do not support Magento 2 version.
Hi, Please note, that we do not support Magento 2 version. Sincerely, Hella
