Inquietud
soria881
soria881 posted this 26 August 2014
Hola me llamo Carlos Soria y tengo una duda cuando uno compra una plantilla esa plantilla ya es de uno o sea con ese pago nadie mas puede tener esa misma plantilla o para que sea tuya hay que hacer un pago adicional ademas si yo tengo al vercion de Artister 4.1 habría algún problema es porque solo veo plantillas y dice para la versión de Artister 4.2 espero su respuesta
Support Team posted this 27 August 2014
Indeed the .artx files are for the Artisteer 4.2 version and higher. And there is no possibility to purchase the template to make it unique. All the users have access to all the templates on the site and it can not be limited.
To have an unique template you should hire a web designer that will be able to create a template for you.
Hi, Indeed the .artx files are for the Artisteer 4.2 version and higher. And there is no possibility to purchase the template to make it unique. All the users have access to all the templates on the site and it can not be limited. To have an unique template you should hire a web designer that will be able to create a template for you. Sincerely, Hella BillionDigital Team
