disable sound from youtube
SH707
SH707 posted this 01 February 2018
How can I disable the sound from the youtube video?
thanks
How can I disable the sound from the youtube video? !youtube.png! thanks
17 Comments
Support Team posted this 02 February 2018
Unfortunately built-in Video control does not support such setting. As alternative you can embed video with desired parameters using HTML control.
Hi, Unfortunately built-in Video control does not support such setting. As alternative you can embed video with desired parameters using HTML control. Thank you, Olivia
SH707
SH707 posted this 02 February 2018
do you have the code?
Simply use the code to embed video (inside iframe) and add ?mute=1 to the video link.
Here is example of the bootstrap responsive embedded video:
https://getbootstrap.com/docs/3.3/components/#responsive-embed
Hi, Simply use the code to embed video (inside iframe) and add `?mute=1` to the video link. Here is example of the bootstrap responsive embedded video: https://getbootstrap.com/docs/3.3/components/#responsive-embed Thank you, Olivia
SH707
SH707 posted this 09 February 2018
hey look my code.... but, i like the video into the middle....
when i make
<iframe width="2000px" ... but i like 100% ???
and who comes ?mute=1 this ?
this is the normal Code:
<div align="center">
<iframe width="2000px" height="500px" src="https://www.youtube.com/embed/7jqRgI0Z5Mw?rel=0&amp;controls=0&amp;showinfo=0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen=""></iframe>
</div>
thanks
hey look my code.... but, i like the video into the middle.... when i make <iframe width="2000px" ... but i like 100% ??? and who comes ?mute=1 this ? this is the normal Code: <div align="center"> <iframe width="2000px" height="500px" src="https://www.youtube.com/embed/7jqRgI0Z5Mw?rel=0&amp;controls=0&amp;showinfo=0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen=""></iframe> </div> thanks
Support Team posted this 12 February 2018
to make it 100% width and to mute try this code:
<iframe width="100%" height="500px" src="https://www.youtube.com/embed/7jqRgI0Z5Mw?rel=0&amp?mute=1;controls=0&amp;showinfo=0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen=""></iframe>
Hi, to make it 100% width and to mute try this code: <iframe width="100%" height="500px" src="https://www.youtube.com/embed/7jqRgI0Z5Mw?rel=0&amp?mute=1;controls=0&amp;showinfo=0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen=""></iframe> Sincerely, Hella
SH707
SH707 posted this 13 February 2018
hi,
thank you or the code.
the problem is when i chance the width to 100% its not working
http://forumattachments.themler.io/944/31944/222.png
hi, thank you or the code. the problem is when i chance the width to 100% its not working http://forumattachments.themler.io/944/31944/222.png
Support Team posted this 13 February 2018
Please export your theme with the content and editor included so we could review the settings.
Hi, Please export your theme with the content and editor included so we could review the settings. Sincerely, Hella
SH707
SH707 posted this 27 February 2018
here is the zip
here is the zip
Support Team posted this 27 February 2018
Set the width 100% to the HTML control also (HTML tab >> HTML menu >> More Options). This will stretch the control itself to fit the slide size.
Hi, Set the width 100% to the HTML control also (HTML tab >> HTML menu >> More Options). This will stretch the control itself to fit the slide size. Thank you, Olivia
SH707
SH707 posted this 28 February 2018
i have the width 100%. but it does not work
Support Team posted this 28 February 2018
Please try HTML width to 100% and enable "Fluid Layout" under the Extensions.
Hi, Please try HTML width to 100% and enable "Fluid Layout" under the Extensions. Thank you, Olivia
SH707
SH707 posted this 01 March 2018
http://seite3.wpcms.de/
ok, but when i start the video is not in the corect form
http://seite3.wpcms.de/ ok, but when i start the video is not in the corect form
Support Team posted this 01 March 2018
When the video starts, some script is adding the inline styles that are resizing the video. We do not control this behavior.
Hi, When the video starts, some script is adding the inline styles that are resizing the video. We do not control this behavior. Sincerely, Hella
SH707
do you have the insline code?
thanks
Hi, do you have the insline code? thanks
SH707
SH707 posted this 08 March 2018
hello?
hello?
Support Team posted this 16 March 2018
Sorry for the delay. The styles inside the iframe cannot be controlled from the theme. The behavior of the video and its size is not controlled by the theme and the theme cannot affect it. Most probably youtube player resizes the video with keeping the aspect ratio. We cannot do anything with it.
Themler Team
Hi, Sorry for the delay. The styles inside the iframe cannot be controlled from the theme. The behavior of the video and its size is not controlled by the theme and the theme cannot affect it. Most probably youtube player resizes the video with keeping the aspect ratio. We cannot do anything with it. Thank you, Themler Team
johnvbalonos
johnvbalonos posted this 16 March 2018
just click on the sound icon in the player, youtube will remember this and next time the sound will be turned off until you turn it on yourself
