Footer widget area information corrupted (after update ?)
ph_denis2000
ph_denis2000 posted this 05 February 2018
I have an inconsistency between the number of footer widget areas actually present in the theme (3) and the number and the number of footer widget areas displayed by the themler (4: "Première zone, Deuxième zone, Troisième zone, Quatrième zone)
It is possible that this problem has appeared since the theme update by themler but I am not sure because this update was made at least a month ago. It is anyway too late to reinstall the backup copy before the update
In the wordpress widget menu, I have the following screen:
But when displaying on the site, only area 1, 2 and 4 appear. Never area 3
I tried to delete and recreate all footer widget areas but I still have the same problem
Could you help me to solve this problem?
Herewith the zip file of the concerned wordpress theme (CTE-6.ZIP)
Best regards,
Philippe
Hello, I have an inconsistency between the number of footer widget areas actually present in the theme (3) and the number and the number of footer widget areas displayed by the themler (4: "Première zone, Deuxième zone, Troisième zone, Quatrième zone) !Footer-widget-areas-info-corrupted.png! It is possible that this problem has appeared since the theme update by themler but I am not sure because this update was made at least a month ago. It is anyway too late to reinstall the backup copy before the update In the wordpress widget menu, I have the following screen: !Third-footer-widget-area-not-really-exist.png! But when displaying on the site, only area 1, 2 and 4 appear. Never area 3 !Footer-widget-areas-on-website.png! I tried to delete and recreate all footer widget areas but I still have the same problem Could you help me to solve this problem? Herewith the zip file of the concerned wordpress theme (CTE-6.ZIP) Best regards, Philippe
Support Team posted this 05 February 2018
Please export the theme with the editor and content included and attach it to the ticket again.
Hi, Please export the theme with the editor and content included and attach it to the ticket again. Sincerely, Hella
ph_denis2000
Thanks for your quick response.
Here is the requested file
Best regards,
Philippe
Thanks for your quick response. Here is the requested file Best regards, Philippe
At the moment there are 3 Footer widget areas in your theme. The screenshot "Footer-widget-areas-info-corrupted.png" shows just widget area name selection. It doesn't mean that all four widget areas should exist. How many widget areas are supposed to be output widgets?
Hello, At the moment there are 3 Footer widget areas in your theme. The screenshot "Footer-widget-areas-info-corrupted.png" shows just widget area name selection. It doesn't mean that all four widget areas should exist. How many widget areas are supposed to be output widgets? Sincerely, Nettie, BillionDigital Team
ph_denis2000
There are 3 footer widget areas supposed to be output widgets but the 3 working areas are the one, two and ... four !?
Best regards,
Philippe
Hello, There are 3 footer widget areas supposed to be output widgets but the 3 working areas are the one, two and ... four !? !footer-widget-areas-three-not-real-area.png! !One-two-four.png! Best regards, Philippe
Hi Philippe,
Just change the most right widget area into the Third Area:
Hi Philippe, Just change the most right widget area into the Third Area: !i485.png! Sincerely, Nettie, BillionDigital Team
ph_denis2000
Thank you for the solution. It works. I have now widgets areas 1, 2, 3 filled and displayed on the screen (and widget area 4 not displayed)
Best regards,
Philippe
Hello, Thank you for the solution. It works. I have now widgets areas 1, 2, 3 filled and displayed on the screen (and widget area 4 not displayed) Best regards, Philippe
Philippe, you are welcome! Please feel free to contact us in any other case.
Philippe, you are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
