WordPress - Google Map Shortcode multiple markers
AureyoBoss
AureyoBoss posted this 06 February 2018
Hi !
How to use multiple marker in Google Map Shortcode ?
Thanks.
Yohan
Hi ! How to use multiple marker in Google Map Shortcode ? Thanks. Yohan
Support Team posted this 06 February 2018
Please try this solution:
https://www.create.net/support/how-to-pin-point-multiple-locations-on-google-maps
You will get the map code тв then it can be added into theme using the HTML control. Make sure that you place the code inside the HTML Source window.
Hi, Please try this solution: https://www.create.net/support/how-to-pin-point-multiple-locations-on-google-maps You will get the map code тв then it can be added into theme using the HTML control. Make sure that you place the code inside the HTML Source window. Sincerely, Hella
msamyiness
msamyiness posted this 2 days ago
Hello AureyoBoss,
If you want to generate multiple markers in the graphical way you should just use Google My Maps tool which is great as a tool to add pinpoints and also then you can embed the map with one simple code to your website.
Once you prefer to code everything on your own, even if you are a non-coder with some help from the Google Developers website it is really simple to add map markers with icons and labels. To do it you must use API Key which is also really easy to generate.
The art which Hella sent is awesome, but if you would like to read an even more extended article about adding multiple markers to Google Maps check this one:
https://nearplace.com/blog/how-to-add-multiple-markers-on-google-maps/
Hello AureyoBoss, If you want to generate multiple markers in the graphical way you should just use Google My Maps tool which is great as a tool to add pinpoints and also then you can embed the map with one simple code to your website. Once you prefer to code everything on your own, even if you are a non-coder with some help from the Google Developers website it is really simple to add map markers with icons and labels. To do it you must use API Key which is also really easy to generate. The art which Hella sent is awesome, but if you would like to read an even more extended article about adding multiple markers to Google Maps check this one: https://nearplace.com/blog/how-to-add-multiple-markers-on-google-maps/
