drupal tool
philippe.pphantom
philippe.pphantom posted this 07 February 2018
"once again it dosn"t work for Drupal ... in one case it refuse the update in the other case it has broken the column"
THE DRUPAL TOOL don't work at all ......in some case i have to rebuild completely the theme from scratch ...
**"once again it dosn"t work for Drupal ... in one case it refuse the update in the other case it has broken the column"** THE DRUPAL TOOL don't work at all ......in some case i have to rebuild completely the theme from scratch ...
11 Comments
Support Team posted this 07 February 2018
Please could you explain all the issue in the details.
Hi, Please could you explain all the issue in the details. Sincerely, Hella
philippe.pphantom
yes when i update, when i can, the outcomes are these ones : lost of one column when if i am unsigned ..
On one of my other i can't update at all.
For the one when i need the most the change , i used Artisteer without a problem but i can't make all ..
yes when i update, when i can, the outcomes are these ones : lost of one column when if i am unsigned .. On one of my other i can't update at all. For the one when i need the most the change , i used Artisteer without a problem but i can't make all .. Regards
philippe.pphantom
philippe.pphantom posted this 12 February 2018
will you correct these bugs or return my money
philippe.pphantom
philippe.pphantom posted this 13 February 2018
no news ?
no news ?
Linkebel
Linkebel posted this 13 February 2018
Philippe si j'étais vous j'arrêterais avec Themler, il faut trouver une alternative car vous vous en doutez leur équipe n'est pas du tout fiable malheureusement.
Vous avez utilisé Artisteer et vous avez vu la fin qu'ils leur ont donné, la même chose va se passer avec Themler et la même chose avec le futur produit, je pense tout simplement qu'ils n'ont pas les épaules assez larges pour couvrir des projets aussi important.
Leur manque de communication est aberrant.
Malheureusement je connais pas bien Drupal si c'est pour du Wordpress je vous conseille fortement le template Divi avec son constructeur de page qui est vraiment une merveille avec des mises à jour régulières et ce depuis des années.
Bref laissez tomber Themelr ça va vous causez plus de problème qu'il serait en résoudre.
Philippe si j'étais vous j'arrêterais avec Themler, il faut trouver une alternative car vous vous en doutez leur équipe n'est pas du tout fiable malheureusement. Vous avez utilisé Artisteer et vous avez vu la fin qu'ils leur ont donné, la même chose va se passer avec Themler et la même chose avec le futur produit, je pense tout simplement qu'ils n'ont pas les épaules assez larges pour couvrir des projets aussi important. Leur manque de communication est aberrant. Malheureusement je connais pas bien Drupal si c'est pour du Wordpress je vous conseille fortement le template Divi avec son constructeur de page qui est vraiment une merveille avec des mises à jour régulières et ce depuis des années. Bref laissez tomber Themelr ça va vous causez plus de problème qu'il serait en résoudre.
philippe.pphantom
et qui êtes vous ?
> Philippe si j'étais vous j'arrêterais avec Themler, il faut trouver une alternative car vous vous en doutez leur équipe n'est pas du tout fiable malheureusement. > > Vous avez utilisé Artisteer et vous avez vu la fin qu'ils leur ont donné, la même chose va se passer avec Themler et la même chose avec le futur produit, je pense tout simplement qu'ils n'ont pas les épaules assez larges pour couvrir des projets aussi important. > > Leur manque de communication est aberrant. > > Malheureusement je connais pas bien Drupal si c'est pour du Wordpress je vous conseille fortement le template Divi avec son constructeur de page qui est vraiment une merveille avec des mises à jour régulières et ce depuis des années. > > Bref laissez tomber Themelr ça va vous causez plus de problème qu'il serait en résoudre. et qui êtes vous ?
Linkebel
Beh rien je suis personne juste un gars qui voulait te donner un conseil, apparement tu t'en fous et en plus tu te permet d'être arrogant.
Sur ce reste dans ta merde et j'espère sincèrement que l'équipe Themeler t'aideras pas. (il y a des fortes chances)
Beh rien je suis personne juste un gars qui voulait te donner un conseil, apparement tu t'en fous et en plus tu te permet d'être arrogant. Sur ce reste dans ta merde et j'espère sincèrement que l'équipe Themeler t'aideras pas. (il y a des fortes chances)
Support Team posted this 22 February 2018
I'm terribly sorry for the delay in responding. Looks like this case was somehow lost in the grid. To help you with the issues you have encountered during the update we need to have your old theme from the back up and also the new one. And we also need several screen shots showing the exact issues. Maybe we could need an access to the site back end then.
Hi, I'm terribly sorry for the delay in responding. Looks like this case was somehow lost in the grid. To help you with the issues you have encountered during the update we need to have your old theme from the back up and also the new one. And we also need several screen shots showing the exact issues. Maybe we could need an access to the site back end then. Sincerely, Hella
philippe.pphantom
philippe.pphantom posted this 22 February 2018
you have the complete description of the case in private msg ... i think that your should find where is the issue easily .. seems that under Drupal themler write the fonts /fonts in one place and read in another place /CSS/Fonts if i transfer from one place to another manualy it's works
philippe.pphantom
so can i have an answer to the question yes or not ... i have paid for a sofware that does work and apparently i am not the only one; will you correct your bugs or not ?
philippe.pphantom
worst you have a new version but nothing for Drupal and thos one don't work at all
