Product Detail
CalamarsCompany!
CalamarsCompany! posted this 08 February 2018
I have other problem in the "product detail" panel, i´m trying to configure style at product at "accessories tab" and I can´t found in "themler" how make this configuration. I attach some files.
Hi, I have other problem in the "product detail" panel, i´m trying to configure style at product at "accessories tab" and I can´t found in "themler" how make this configuration. I attach some files. Thanks
Support Team posted this 08 February 2018
The styling for Product Tabs can be set in teh Product Details tab >> Product Tabs. Do you mean some specific option?
Hello, The styling for Product Tabs can be set in teh Product Details tab >> Product Tabs. Do you mean some specific option? Sincerely, Nettie, BillionDigital Team
CalamarsCompany!
Yes, but I need change the style to "accesorries" and I can´t see where is this option.
Support Team posted this 09 February 2018
The Accessories is the Product Slider and it uses default Product Slider styles. The slider columns can be configured under the PS >> Billion Themler >> Theme Options.
if you want to access this slider in Themler you need the product which has accessories specified in PS. The product can be opened by right Click >> Open Link. Currently you see the product without accessories when you open Product Details template in Themler.
Hi, The Accessories is the Product Slider and it uses default Product Slider styles. The slider columns can be configured under the PS >> Billion Themler >> Theme Options. if you want to access this slider in Themler you need the product which has accessories specified in PS. The product can be opened by right Click >> Open Link. Currently you see the product without accessories when you open Product Details template in Themler. Thank you, Olivia
