wordpress header php not acessable
lavisbre
lavisbre posted this 2 weeks ago
Hi I have no plugins added yet i cant add analytics to header php in wordpress
is this our issue or ipage?
i went to Ipage and added to file manager header php
went back to wordpress dash bord but no change ?
added in WP dashbord and it said cant except change?
have you seen this before, whats the fix?
Hi I have no plugins added yet i cant add analytics to header php in wordpress is this our issue or ipage? i went to Ipage and added to file manager header php went back to wordpress dash bord but no change ? added in WP dashbord and it said cant except change? have you seen this before, whats the fix?
lavisbre
I have had an advancement
i can alter my header php file in ipage server and add analytic code.
yet it won't update in my WP dashboard header.php?
I can now update my analytic code in WP dashboard but it wont update Ipage header.php?
Even though i have analytic code in the header.php in both ipage file manager and WordPress header.php
Google analytic cant see its code in the header?
is this a themlar issue anyone knows the fix for?
is this a wordpress error people know about and have a fix?
is there anyone that can point me in the right direction?
I have had an advancement i can alter my header php file in ipage server and add analytic code. yet it won't update in my WP dashboard header.php? I can now update my analytic code in WP dashboard but it wont update Ipage header.php? Even though i have analytic code in the header.php in both ipage file manager and WordPress header.php Google analytic cant see its code in the header? is this a themlar issue anyone knows the fix for? is this a wordpress error people know about and have a fix? is there anyone that can point me in the right direction?
lavisbre
lavisbre posted this 1 weeks ago
I see word press has some header bugs ver 4.9.4 now installed and still the header wont fix
You can easily test if this is the Themler issue. Use another non-Themler theme in WP, perform the desired modifications and see if that works fine.
Hi, You can easily test if this is the Themler issue. Use another non-Themler theme in WP, perform the desired modifications and see if that works fine. Sincerely, Hella
lavisbre
I agree and didnt have any success with the free ones on offer.
ipage said this
have resolved the issue which you were experiencing in verifying your website https://seo-inbound-marketing.com/with Google. You had added the Google Analytics code to the Primary Widget Area at https://seo-inbound-marketing.com/wp-admin/widgets.php . This widget area is not common to all the pages, so Google was unable to verify your website. I have added the Google Analytics code to the website footer at https://seo-inbound-marketing.com/wp-admin/themes.php?page=functions.php , which is common to all pages. Now the codes is appearing in source of all page and you should be able to verify your domain with Google without any issues.
I still cant get google search console to see my site and verifie. as for adding my analytic code to the footer.. is that wise?
I agree and didnt have any success with the free ones on offer. ipage said this have resolved the issue which you were experiencing in verifying your website https://seo-inbound-marketing.com/with Google. You had added the Google Analytics code to the Primary Widget Area at https://seo-inbound-marketing.com/wp-admin/widgets.php . This widget area is not common to all the pages, so Google was unable to verify your website. I have added the Google Analytics code to the website footer at https://seo-inbound-marketing.com/wp-admin/themes.php?page=functions.php , which is common to all pages. Now the codes is appearing in source of all page and you should be able to verify your domain with Google without any issues. ................................................................................................................................................................................. I still cant get google search console to see my site and verifie. as for adding my analytic code to the footer.. is that wise?
The most recent Themler update (438) includes header.php file. As alternative you can try to add CMS Code or HTML control into the Header directly in Themler depending on what exactly code you're using.
Did you try it?
Hello, The most recent Themler update (438) includes header.php file. As alternative you can try to add CMS Code or HTML control into the Header directly in Themler depending on what exactly code you're using. Did you try it? Thank you, Olivia
