bullet list in a text in joomla
arawolf
arawolf posted this 15 February 2018
How can i combine text and a bullet list in the same textcontainer.
8 Comments
Support Team posted this 15 February 2018
Do you mean Joomla article or a text control? In any case, you may use HTML editing mode for this. For the Text control it is available in the Text tab.
Hello, Do you mean Joomla article or a text control? In any case, you may use HTML editing mode for this. For the Text control it is available in the Text tab. Sincerely, Nettie, BillionDigital Team
arawolf
in a text control. It won't work, every thing go in a list.
Support Team posted this 16 February 2018
You can edit the Text control HTML source code and remove <li> </li> tags from the elements that should not be in the list. But it will be more convenient to use another Text control for the plain text.
Hi, You can edit the Text control HTML source code and remove `<li> </li>` tags from the elements that should not be in the list. But it will be more convenient to use another Text control for the plain text. Sincerely, Hella
arawolf
arawolf posted this 16 February 2018
I know but please look at the printscreens. I put the il tags in the text and next i get a error message
You cannot put the tags in the Text control editor. I meant that if you add the list using the list button when it adds it to the whole text, then in the editor you can remove them for the undesired items. BTW, you have spelled the tag wrong. It should be li and not il. In any case, the best solution is to use different Text controls.
You cannot put the tags in the Text control editor. I meant that if you add the list using the list button when it adds it to the whole text, then in the editor you can remove them for the undesired items. BTW, you have spelled the tag wrong. It should be `li` and not `il`. In any case, the best solution is to use different Text controls. Sincerely, Hella
arawolf
ok, can this option maybe realised in a future version of themler.
I'm not sure about that, but I'll add it to our wish list.
Hi, I'm not sure about that, but I'll add it to our wish list. Sincerely, Hella
arawolf
thnxs
thnxs
