HTML: Table nor responsive
brizzicomunicazione
brizzicomunicazione posted this 23 February 2018
I added a table in HTML format, but in the mobile view, the table does not fit and is half unreadable
How can I do? Thank you.
Best regards
Walt
Hi, I added a table in HTML format, but in the mobile view, the table does not fit and is half unreadable How can I do? Thank you. Best regards Walt
Support Team posted this 26 February 2018
Have you set the table width to be 100%? In some sites you can use the horizontal scroll for the table only so it will be seen on the phone when swiped. Let me know if that is a possible solution for you. And also provide a link to the site.
Hi, Have you set the table width to be 100%? In some sites you can use the horizontal scroll for the table only so it will be seen on the phone when swiped. Let me know if that is a possible solution for you. And also provide a link to the site. Sincerely, Hella
brizzicomunicazione
brizzicomunicazione posted this 26 February 2018
Yes,
I tried with 2 parameters: 100% and "auto".
The problem does not seem to resolve.
I have read that there are several systems to introduce a scroll bar with HTML and CSS in the table.
I'm not a wizard of codes and in fact I could not solve.
Do you have any suggestions?
This is the doive link to find the table: https://www.brizzicomunicazione.it/i-servizi/descrizione-e-prezzo-servizi.htm
Beste regards,
Walt
Yes, I tried with 2 parameters: 100% and "auto". The problem does not seem to resolve. I have read that there are several systems to introduce a scroll bar with HTML and CSS in the table. I'm not a wizard of codes and in fact I could not solve. Do you have any suggestions? This is the doive link to find the table: https://www.brizzicomunicazione.it/i-servizi/descrizione-e-prezzo-servizi.htm Beste regards, Walt
The site gives me this error:
Impossibile visualizzare la pagina a causa di un errore interno del server.
Please check. It might be because the site is blocked for some countries.
Hi, The site gives me this error: *Impossibile visualizzare la pagina a causa di un errore interno del server.* Please check. It might be because the site is blocked for some countries. Sincerely, Hella
brizzicomunicazione
Hella, try now here please: https://www.brizzicomunicazione.it/i-servizi/descrizione-e-prezzo-servizi.html
The html TABLE element is not responsive by itself. If you use the code cor this table in a blank HTML page created outside Themler and preview it on small mobile screen you will see the same problem.
The table cannot become shorter than the longest word or phrase with   like in E) row.
Hi, The html TABLE element is not responsive by itself. If you use the code cor this table in a blank HTML page created outside Themler and preview it on small mobile screen you will see the same problem. The table cannot become shorter than the longest word or phrase with ` ` like in `E)` row. Thank you, Olivia
brizzicomunicazione
Hi Olivia,
considering that there is not a function that allows you to create a table directly with Themler, after reading many technical articles, I have identified the best method with the "No More Tables" technique.
When I have finished, it will be perfect!
For anyone who wanted to deepen is a combination of HTML code and CSS code (a bit laborious, but very simple), which transforms columns into rows in devices with the reduced screen: https://www.cosedelweb.it/come-creare-tabelle-responsive-con-no-more-tables
Hi Olivia, considering that there is not a function that allows you to create a table directly with Themler, after reading many technical articles, I have identified the best method with the "No More Tables" technique. When I have finished, it will be perfect! For anyone who wanted to deepen is a combination of HTML code and CSS code (a bit laborious, but very simple), which transforms columns into rows in devices with the reduced screen: https://www.cosedelweb.it/come-creare-tabelle-responsive-con-no-more-tables
Please let us know if you need our further assistance with this case.
Hi, Please let us know if you need our further assistance with this case. Thank you, Olivia
