Headline font size issue
cachou93
cachou93 posted this 01 March 2018
Is it possible to change the size of the headline font? The font size of the headline is bigger when I hover the mouse over it. Any solutions, please? that is a Joomla theme.
Hello, Is it possible to change the size of the headline font? The font size of the headline is bigger when I hover the mouse over it. Any solutions, please? that is a Joomla theme. Thank you
15 Comments
Support Team posted this 01 March 2018
For this please select the Headline in Themler and go to the Headline tab >> Hover >> Size and adjust the size.
Hello, For this please select the Headline in Themler and go to the Headline tab >> Hover >> Size and adjust the size. Sincerely, Nettie, BillionDigital Team
cachou93
Thank you for your reply.
Just to let you know that the hover size is the one I want to keep. How can I resize the headline font size before I hover. I would like the headline font size to be the same as the size of the font when I hover the mouse over the headline.
Hello, Thank you for your reply. Just to let you know that the hover size is the one I want to keep. How can I resize the headline font size before I hover. I would like the headline font size to be the same as the size of the font when I hover the mouse over the headline.
Support Team posted this 02 March 2018
Then simply set the same font size value for the Headline text. If that does not help, provide your theme for the investigation.
Hi, Then simply set the same font size value for the Headline text. If that does not help, provide your theme for the investigation. Sincerely, Hella
cachou93
cachou93 posted this 03 March 2018
Hi Hella,
The fact is that I don't have the function that let me change the size value for the Headline text. I have it for the link and the link hover. Please find attached my theme.
Thank you for your assistance.
Hi Hella, The fact is that I don't have the function that let me change the size value for the Headline text. I have it for the link and the link hover. Please find attached my theme. Thank you for your assistance.
Support Team posted this 05 March 2018
The problem is that you have overriden the proper font settings by settings the font value to 24px under the Section >> Text Styles >> H3. I mean the section that is inside the header and includes the headline control.
Hi, The problem is that you have overriden the proper font settings by settings the font value to 24px under the Section >> Text Styles >> H3. I mean the section that is inside the header and includes the headline control. Sincerely, Hella
cachou93
cachou93 posted this 05 March 2018
I followed your instructions and amended the font value to 48px and it still did not work. Please see screenshot attached showing the steps I went through.
Any other suggestions, please?
Hi, I followed your instructions and amended the font value to 48px and it still did not work. Please see screenshot attached showing the steps I went through. Any other suggestions, please?
It's also set for the Section >> Text Styles >> H3 >> Link and you can open it's drop-down options and press Clear button to remove those styles.
Hi, It's also set for the Section >> Text Styles >> H3 >> Link and you can open it's drop-down options and press Clear button to remove those styles. Sincerely, Hella
cachou93
Can you please let me know to which section you are referring to? I went through all the sections available for the Header. I don't want the font sizes of the menu to change.
Please advise.
Can you please let me know to which section you are referring to? I went through all the sections available for the Header. I don't want the font sizes of the menu to change. Please advise.
That is the same section. Please refer to the screen shot:
Hi, That is the same section. Please refer to the screen shot: !headline-font.png! Sincerely, Hella
cachou93
Thank you 😊, 🙏 I got it now
cachou93
Hi Hella,
I have still something that I don't understand. Now, I have the headline title like I want but in the process, the font size of the horizontal menu items also have changed size. How can I address that?
Hi Hella, I have still something that I don't understand. Now, I have the headline title like I want but in the process, the font size of the horizontal menu items also have changed size. How can I address that? Thank you
Support Team posted this 06 March 2018
Attach the copy of the edited theme and also a screen shot demonstrating how the menu should look like.
Hi, Attach the copy of the edited theme and also a screen shot demonstrating how the menu should look like. Sincerely, Hella
cachou93
cachou93 posted this 08 March 2018
Sorry for the late reply.
Please find attached the requested elements.
Thank you for your help.
Hello, Sorry for the late reply. Please find attached the requested elements. Thank you for your help.
Support Team posted this 16 March 2018
Sorry for the delay.
The menu items do not have the size specified and inherit the following style from the Section settings:
To avoid this please set the size for menu items directly.
Hi, Sorry for the delay. The menu items do not have the size specified and inherit the following style from the Section settings: !menu-items-links.png! To avoid this please set the size for menu items directly. Thank you, Olivia
