images disappear from wordpress themes
design34
design34 posted this 08 March 2018
This happens repeatedly on several themes made using the themler app. How to fix to keep this from happening?
http://web-design-demo.biz/built-to-suit/
The right column images have vanished after several months of non issue. Amazing isn't it?
This happens repeatedly on several themes made using the themler app. How to fix to keep this from happening? http://web-design-demo.biz/built-to-suit/ The right column images have vanished after several months of non issue. Amazing isn't it?
design34
design34 posted this 09 March 2018
I figured out what the problem was, you had control over the images and lost them. Nice! I had to recreate and store them on my server out of your reach. What is your view as to your softwares failure? I am curious as to how Olivia will bushit her way out of this.
design34
Who do we send the bill to for all the wasted hours using this fucked up software?
Support Team posted this 12 March 2018
Now the images are in place as you have probably solved the problem. But I'm not sure what we can investigate without having the initial image path that caused the issue. Probably you have saved the image path that caused this issue?
Hi, Now the images are in place as you have probably solved the problem. But I'm not sure what we can investigate without having the initial image path that caused the issue. Probably you have saved the image path that caused this issue? Sincerely, Hella
