The module comes out of frame
vitalii.reznic
vitalii.reznic posted this 08 March 2018
I use a joomla position in sidebar/ Why its content comes ot of frame?!
this module on the site
this module in themler
I use a joomla position in sidebar/ Why its content comes ot of frame?! [this module on the site][1] ![this module in themler][2] [1]: https://ibb.co/jX3vk7 [2]: https://ibb.co/kNueCn
vitalii.reznic
Why the content is displaye here?
![content nust be inside the sidebar][1]
http://tinypic.com/r/e7xwdt/9
Why the content is displaye here? ![content nust be inside the sidebar][1] http://tinypic.com/r/e7xwdt/9
Support Team posted this 10 March 2018
Unfortunately I cannot say anything specific without seeing the issue on my side but this could be positioning problem or you applied Boxed extension to the Block or Block Content or Joomla position controls.
Hi, Unfortunately I cannot say anything specific without seeing the issue on my side but this could be positioning problem or you applied Boxed extension to the Block or Block Content or Joomla position controls. Thank you, Olivia
vitalii.reznic
vitalii.reznic posted this 11 March 2018
It helped me with menu. Now How can I prevent overlaying of position (right) with the footer. Right position is sticky.I want, that this module, when it touches the footer will stop scorlling (because a part of content go under the footer, and it`s impossible to see it)
there is my  issue
> Hi, > > Unfortunately I cannot say anything specific without seeing the issue on my side but this could be positioning problem or you applied Boxed extension to the Block or Block Content or Joomla position controls. > > Thank you, > Olivia It helped me with menu. Now How can I prevent overlaying of position (right) with the footer. Right position is sticky.I want, that this module, when it touches the footer will stop scorlling (because a part of content go under the footer, and it`s impossible to see it) ![there is my issue][1] [1]: http://i.piccy.info/i9/ca32226c3e63802b8fd3ae3f5b01a418/1520803490/292680/1228327/Sans_titre.jpg
Support Team posted this 12 March 2018
Unfortunately this feature is not supported. The sticky element cannot stop scrolling.
Hi, Unfortunately this feature is not supported. The sticky element cannot stop scrolling. Thank you, Olivia
vitalii.reznic
vitalii.reznic posted this 17 March 2018
ok. Then what how can I mask this overlaying , that sidebar goes under footer. I tried to change different parameters, but nothing doesn`t help (also I changed Z- index)
<a href><img src alt border></a>
> Hi, > > Unfortunately this feature is not supported. The sticky element cannot stop scrolling. > > Thank you, > Olivia ok. Then what how can I mask this overlaying , that sidebar goes under footer. I tried to change different parameters, but nothing doesn`t help (also I changed Z- index) &lt;a href&gt;&lt;img src alt border&gt;&lt;/a&gt;
vitalii.reznic
I want the sidebar go under footer
https://ibb.co/g7yokH
> Hi, > > Unfortunately this feature is not supported. The sticky element cannot stop scrolling. > > Thank you, > Olivia ok. Then what how can I mask this overlaying , that sidebar goes under footer. I tried to change different parameters, but nothing doesn`t help (also I changed Z- index) I want the sidebar go under footer https://ibb.co/g7yokH &lt;a href&gt;&lt;img src alt border&gt;&lt;/a&gt;
Support Team posted this 19 March 2018
If the site is not live, please attach the theme exported with the content and editor included. So we could see the issue on our end.
Hi, If the site is not live, please attach the theme exported with the content and editor included. So we could see the issue on our end. Sincerely, Hella
