Product title as H3
ZCompany
ZCompany posted this 09 March 2018
Hi!
I'm using a Woocommerce theme. I wonder how can the product titles in Product Slider and Category Grid view to be H3? Is it possible at all?
Hi! I'm using a Woocommerce theme. I wonder how can the product titles in Product Slider and Category Grid view to be H3? Is it possible at all?
Support Team posted this 10 March 2018
Unfortunately the heading tag used for titles cannot be changed. If you know coding you can try to replace the title control with CMS Code control and add the code which displays the title wrapped into the desired tags.
Hi, Unfortunately the heading tag used for titles cannot be changed. If you know coding you can try to replace the title control with CMS Code control and add the code which displays the title wrapped into the desired tags. Thank you, Olivia
