Using Theme Customizer
TJ Novick
TJ Novick posted this 10 March 2018
WooCommerce uses the WP Theme Customizer for the product descriptions and other features but When I go to the Theme Customizer page I get the error that I cannot edit the theme in customizer. Can someone explain to me how I can edit woocommerce features in the customizer?
Also I was wondering how to change default font and size of theme. Thanks
WooCommerce uses the WP Theme Customizer for the product descriptions and other features but When I go to the Theme Customizer page I get the error that I cannot edit the theme in customizer. Can someone explain to me how I can edit woocommerce features in the customizer? Also I was wondering how to change default font and size of theme. Thanks
Support Team posted this 12 March 2018
The WP Customizer option does not work with the Themler theme. You need to run Themler editor in order to edit the theme.
As for the default font, it can be set under the Design tab. But note, that if you set another font to some specific elements, it will override the default setting.
Hi, The WP Customizer option does not work with the Themler theme. You need to run Themler editor in order to edit the theme. As for the default font, it can be set under the Design tab. But note, that if you set another font to some specific elements, it will override the default setting. Sincerely, Hella
Seagull
Seagull posted this 18 March 2018
I've asked about this before on here and received the same reply. Personally I think it is very shortsighted and limits the resale value of themes created with Themler.
The customizer is not just for editing the theme, it is also very handy for visually editing and arranging widgets and menus, much faster than doing it through the themes/widget or theme/menu page in admin as you get instant feedback as to how it looks, this is really important to clients.
All the customizer needs to contain for Themler is the ability to add/change the logo, site icon, site name, widgets and menus. Everything else is done by the theme creator in Themler.
> Hi, > > The WP Customizer option does not work with the Themler theme. You need to run Themler editor in order to edit the theme. > > As for the default font, it can be set under the Design tab. But note, that if you set another font to some specific elements, it will override the default setting. > > Sincerely, > Hella I've asked about this before on here and received the same reply. Personally I think it is very shortsighted and limits the resale value of themes created with Themler. The customizer is not just for editing the theme, it is also very handy for visually editing and arranging widgets and menus, much faster than doing it through the themes/widget or theme/menu page in admin as you get instant feedback as to how it looks, this is really important to clients. All the customizer needs to contain for Themler is the ability to add/change the logo, site icon, site name, widgets and menus. Everything else is done by the theme creator in Themler.
