Drupal 8
mostafax222
mostafax222 posted this 14 March 2018
when add new layer show error :
OS: Darwin Mostafas-MacBook-Air.local 16.7.0 Darwin Kernel Version 16.7.0: Thu Jan 11 22:59:40 PST 2018; root:xnu-3789.73.8~1/RELEASE_X86_64 x86_64 E_NOTICE: A non well formed numeric value encountered /Applications/MAMP/htdocs/mostafa/modules/themler/src/helpers/pclzip/pclzip.lib.php 1845 Callstack: -> PclZip::privOptionDefaultThreshold(array(2) { ... }) -> PclZip::extract(77001, '/Applicati...') -> Chunk::unzip('PK ...') -> Chunk::complete() -> export('untitled', array(7) { ... }) -> themler_export() -> themler_process_request('process_re...') -> Drupal\themler\Controller\ThemlerController::process_request('process_re...') -> call_user_func_array(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber{closure}() -> Drupal\Core\Render\Renderer::executeInRenderContext(Drupal\Core\Render\RenderContext(...) { ... }, Closure(...) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::wrapControllerExecutionInRenderContext(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber{closure}() -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
when add new layer show error : OS: Darwin Mostafas-MacBook-Air.local 16.7.0 Darwin Kernel Version 16.7.0: Thu Jan 11 22:59:40 PST 2018; root:xnu-3789.73.8~1/RELEASE_X86_64 x86_64 E_NOTICE: A non well formed numeric value encountered /Applications/MAMP/htdocs/mostafa/modules/themler/src/helpers/pclzip/pclzip.lib.php 1845 Callstack: -> PclZip::privOptionDefaultThreshold(array(2) { ... }) -> PclZip::extract(77001, '/Applicati...') -> Chunk::unzip('PK ...') -> Chunk::complete() -> export('untitled', array(7) { ... }) -> themler_export() -> themler_process_request('process_re...') -> Drupal\themler\Controller\ThemlerController::process_request('process_re...') -> call_user_func_array(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber\{closure}() -> Drupal\Core\Render\Renderer::executeInRenderContext(Drupal\Core\Render\RenderContext(...) { ... }, Closure(...) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::wrapControllerExecutionInRenderContext(Drupal\themler\Controller\ThemlerController->process_request, array(1) { ... }) -> Drupal\Core\EventSubscriber\EarlyRenderingControllerWrapperSubscriber::Drupal\Core\EventSubscriber\{closure}() -> Symfony\Component\HttpKernel\HttpKernel::handleRaw(Symfony\Component\HttpFoundation\Request(...) { ... }, 1) -> Symfony\Component\HttpKernel\HttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\Session::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\KernelPreHandle::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::pass(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\page_cache\StackMiddleware\PageCache::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\ReverseProxyMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\StackMiddleware\NegotiationMiddleware::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Stack\StackedHttpKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... }, 1, true) -> Drupal\Core\DrupalKernel::handle(Symfony\Component\HttpFoundation\Request(...) { ... })
Support Team posted this 14 March 2018
Please try adding the following line around the 1839 line in the
file:
$v_memory_limit = substr($v_memory_limit, 0, -1);
Does the issue continue?
Hi, Please try adding the following line around the 1839 line in the /modules/themler/src/helpers/pclzip/pclzip.lib.php file: `$v_memory_limit = substr($v_memory_limit, 0, -1);` Does the issue continue? Thank you, Olivia
mostafax222
mostafax222 posted this 15 March 2018
working good
Thanks Olivia
working good Thanks Olivia
Support Team posted this 15 March 2018
Great!
Please use this solution if you encounter this issue with the future projects.
Hi, Great! Please use this solution if you encounter this issue with the future projects. Thank you, Olivia
