Product slider
williamvanveen1988
williamvanveen1988 posted this 20 March 2018
Dear support,
I like to add product slider buth i don't see any woocommerce actions anymore only cart option.
See:
http://www.demo-webdesign.nl/demicosports/
I like to add some action products into the underside.
How i can do this?
See screenshots:
Dear support, I like to add product slider buth i don't see any woocommerce actions anymore only cart option. See: http://www.demo-webdesign.nl/demicosports/ I like to add some action products into the underside. How i can do this? See screenshots: !2018-03-20-10-21-41.png! !2018-03-20-10-22-29.png!
Support Team posted this 20 March 2018
Product Slider will appear if you put a corresponding wooCommerce widget into a sidebar in Wordpress admin. For more information please refer to https://answers.themler.io/articles/4780/product-slider-ecommerce.
Hello, Product Slider will appear if you put a corresponding wooCommerce widget into a sidebar in Wordpress admin. For more information please refer to https://answers.themler.io/articles/4780/product-slider-ecommerce. Sincerely, Nettie, BillionDigital Team
williamvanveen1988
williamvanveen1988 posted this 23 March 2018
When i add the widget i get this ( Insert into already standing section)
When i add directly the widget i get strange position widget but there is the option with the products :)
How to fix this?
Here a picture:
When i add the widget i get this ( Insert into already standing section) When i add directly the widget i get strange position widget but there is the option with the products :) How to fix this? Here a picture: !2018-03-23-10-06-43.png!
Support Team posted this 23 March 2018
Please make sure to add the Wordpress Widget Area control in Themler directly into some Sidebar. A similar issue like on your screenshot can appear if you add it into the content area.
Hello, Please make sure to add the Wordpress Widget Area control in Themler directly into some Sidebar. A similar issue like on your screenshot can appear if you add it into the content area. Sincerely, Nettie, BillionDigital Team
williamvanveen1988
Dear Nettie,
I like to make it on the homepage without sidebars. Like to have nice product slider between the content.
How to do this.
Kind regards,
William
Dear Nettie, I like to make it on the homepage without sidebars. Like to have nice product slider between the content. How to do this. Kind regards, William
Hello William,
In this case I would recommend you to put the Widget Area to the Template (blue) part, above or under the content. It is not possible to put it into the content. If you would like to place some text or images under the product slider, you may consider using Text or Image controls from Themler >> Insert.
Hello William, In this case I would recommend you to put the Widget Area to the Template (blue) part, above or under the content. It is not possible to put it into the content. If you would like to place some text or images under the product slider, you may consider using Text or Image controls from Themler >> Insert. Sincerely, Nettie, BillionDigital Team
