Shortcode issue
moordigital
moordigital posted this 26 March 2018
I have purchased a plugin (https://codecanyon.net/item/events-schedule-wordpress-plugin/14907462) and am setting it up on a website (currently offline) - I have discovered one issue that I cannot seem to resolve... I am using Themler to build my Wordpress website template and the shortcodes only seem to work when added to the page/post content. When I add the shortcode within Themler as either text or html it just shows [wcs-schedule id=2] rather than the slider as set up. It does, work fine however when added to the page content - but this restricts me from actually positioning where I want it.
I contacted the plugin creators and they replied as follows:
"We are not familiar with Themler, so we can't say if there are any compatibility issues. Still, we are committed to good WP practices and we stick to plugin territory, so they might have a solution for this. You should contact their support and ask if you can use WP shortcodes in that particular section and if they support Vue JS script content. Since that section displays the naked shortcode, that might not be the way you can integrate shortcodes with their solution. Please contact their support and let us know how it goes."
Please advise.
Many thanks in advance.
Angus
Hi, I have purchased a plugin (https://codecanyon.net/item/events-schedule-wordpress-plugin/14907462) and am setting it up on a website (currently offline) - I have discovered one issue that I cannot seem to resolve... I am using Themler to build my Wordpress website template and the shortcodes only seem to work when added to the page/post content. When I add the shortcode within Themler as either text or html it just shows [wcs-schedule id=2] rather than the slider as set up. It does, work fine however when added to the page content - but this restricts me from actually positioning where I want it. I contacted the plugin creators and they replied as follows: "We are not familiar with Themler, so we can't say if there are any compatibility issues. Still, we are committed to good WP practices and we stick to plugin territory, so they might have a solution for this. You should contact their support and ask if you can use WP shortcodes in that particular section and if they support Vue JS script content. Since that section displays the naked shortcode, that might not be the way you can integrate shortcodes with their solution. Please contact their support and let us know how it goes." Please advise. Many thanks in advance. Angus
Support Team posted this 27 March 2018
Have you tried to use the Shortcode control available from the Insert >> More tab? That control can be positioned within the section and should render the third-party shortcodes just fine.
Hi, Have you tried to use the *Shortcode* control available from the Insert >> More tab? That control can be positioned within the section and should render the third-party shortcodes just fine. Sincerely, Hella
moordigital
moordigital posted this 27 March 2018
Spot on - many thanks! I was looking for exactly that but couldn't find it when clicking the small plus in the circle to add content etc.
Sorted. Cheers for your help.
Spot on - many thanks! I was looking for exactly that but couldn't find it when clicking the small plus in the circle to add content etc. Sorted. Cheers for your help.
Dana
Dana posted this 05 October 2018
I have the same issue with shortcode integration. I want to insert a Slider with a shortcode and the shortcode control but it's not displaying. only the correct size is shown of the box of the slyer but with empty slider. How can I solve that? thanks in advance.
Hi, I have the same issue with shortcode integration. I want to insert a Slider with a shortcode and the shortcode control but it's not displaying. only the correct size is shown of the box of the slyer but with empty slider. How can I solve that? thanks in advance.
