Virtuemart Captcha field not appearing in user registration form
richard25
richard25 posted this 27 March 2018
I've turned on the Joomla recaptcha plugin and inserted the keys but the form below will not display the recaptcha field
https://antiligatureshopdirect.com/user/editaddresscartbt
I know it's working because the standard Joomla registration form link below displays it
https://antiligatureshopdirect.com/create-an-account/
I thought about adding a custom field but cannot find one for recaptcha
Cheers
Hi I've turned on the Joomla recaptcha plugin and inserted the keys but the form below will not display the recaptcha field https://antiligatureshopdirect.com/user/editaddresscartbt I know it's working because the standard Joomla registration form link below displays it https://antiligatureshopdirect.com/create-an-account/ I thought about adding a custom field but cannot find one for recaptcha Cheers
richard25
richard25 posted this 29 March 2018
Could support please get back to me on this?
Is there a shortcode I need to add to my template? If so what is it?
Hi Could support please get back to me on this? Is there a shortcode I need to add to my template? If so what is it? Thanks
Support Team posted this 10 April 2018
Sorry for the delay.
Does it work with the default joomla theme? Do you know how to make it work with the default Joomla theme?
As far as I know it needs a piece of html at the end of the form. The login form is controlled by joomla, not the theme.
If you're using joomla plugin please check for the option to change default website captcha under the Global Configuration. This may help too.
Hi, Sorry for the delay. Does it work with the default joomla theme? Do you know how to make it work with the default Joomla theme? As far as I know it needs a piece of html at the end of the form. The login form is controlled by joomla, not the theme. If you're using joomla plugin please check for the option to change default website captcha under the Global Configuration. This may help too. Thank you, Olivia
richard25
richard25 posted this 11 April 2018
Hi Olivia
I did it as follows, hopefully you can verify this is correct or at least there is no better way of doing it that you know off.
A. Login to Google Recaptcha and create a site captcha for your website
B. Activate recaptcha for VM User Registration form
VM/Configuration/Shop Tab Tick the box ‘Use ReCaptcha for Registration’ Save & Close
Enable the ‘Captcha Recaptcha’ Joomla recaptcha plugin select version 2 and input Google recaptcha Site & Secret key
In Joomla Global Settings - Set Default Captcha as ‘Captcha - Recaptcha’
In Joomla User/Manage/Options - Select Allow user registration to ‘No’ and Captcha as ‘Captcha - Recaptcha’ (This prevents normal Joomla registration but allows Virtuemart User Registration with recaptcha)
C. Showing recaptcha in Themler Template
Insert the Google Recaptcha Client Side integration Snippet into the bottom of the Registration Default page below(Just before )
templatename/html/com_virtuemart/edit_address.php
The Snippet can be found in the Google recaptcha site listing under the title ‘Paste this snippet at the end of the <form> where you want the reCAPTCHA widget to appear:’
Eg as per snippet example below
<div class data-sitekey>Etc etc etc etc</div>
Richard
Hi Olivia I did it as follows, hopefully you can verify this is correct or at least there is no better way of doing it that you know off. A. Login to Google Recaptcha and create a site captcha for your website B. Activate recaptcha for VM User Registration form VM/Configuration/Shop Tab Tick the box ‘Use ReCaptcha for Registration’ Save & Close Enable the ‘Captcha Recaptcha’ Joomla recaptcha plugin select version 2 and input Google recaptcha Site & Secret key In Joomla Global Settings - Set Default Captcha as ‘Captcha - Recaptcha’ In Joomla User/Manage/Options - Select Allow user registration to ‘No’ and Captcha as ‘Captcha - Recaptcha’ (This prevents normal Joomla registration but allows Virtuemart User Registration with recaptcha) C. Showing recaptcha in Themler Template Insert the Google Recaptcha Client Side integration Snippet into the bottom of the Registration Default page below(Just before </form>) templatename/html/com_virtuemart/edit_address.php The Snippet can be found in the Google recaptcha site listing under the title ‘Paste this snippet at the end of the &lt;form&gt; where you want the reCAPTCHA widget to appear:’ Eg as per snippet example below &lt;div class data-sitekey&gt;Etc etc etc etc&lt;/div&gt; Regards Richard
Support Team posted this 20 April 2018
Sorry for the delay. The steps look ok. Unfortunately I don't know another solution.
As I can see you already added captcha to the form here:
Where else you want to add captcha also?
Hi, Sorry for the delay. The steps look ok. Unfortunately I don't know another solution. As I can see you already added captcha to the form here: https://antiligatureshopdirect.com/user/editaddresscartbt Where else you want to add captcha also? Thank you, Olivia
