System Requirements
Basics in Motion
Basics in Motion posted this 03 April 2018
Good Morning
I am running Themler on Windows 10, 64 Bit, 4gb Memory, Intel Celeron 2,41GHz processor, I have a good internet connection When editing it is extremley slow, so much so that i am thinking of abandoning it.
Can you please mail me back with the optimum system requirements to run themler so I can overcome this issue.
Thanks in advance
Good Morning I am running Themler on Windows 10, 64 Bit, 4gb Memory, Intel Celeron 2,41GHz processor, I have a good internet connection When editing it is extremley slow, so much so that i am thinking of abandoning it. Can you please mail me back with the optimum system requirements to run themler so I can overcome this issue. Thanks in advance
10 Comments
Support Team posted this 03 April 2018
It's indeed low performance on your end. It is usually caused by the anti virus applications. They are blocking the application from accessing some parts and that slows down the performance. So please once again disable all anti virus applications. Also please list what anti virus applications are installed on your computer.
Then let us know if any other heavy applications are running on your computer and if they are also slowed down.
Hi, It's indeed low performance on your end. It is usually caused by the anti virus applications. They are blocking the application from accessing some parts and that slows down the performance. So please once again disable all anti virus applications. Also please list what anti virus applications are installed on your computer. Then let us know if any other heavy applications are running on your computer and if they are also slowed down. Sincerely, Hella
Also please run Task Manager while Themler is running, switch to the Performance tab and attach a screen shot of that screen.
Hi, Also please run Task Manager while Themler is running, switch to the Performance tab and attach a screen shot of that screen. Sincerely, Hella
Basics in Motion
Dear Hella
Thank you for your response, I do not have any anti virus software running as far as I can see just windows defender.
I have attached, task manager processes and performance, please bear in mind Team viewer is not normally running, I use this to connect to my PC when I am at work, so please discount this from your assessment.
I am thinking of increasing the memory to 8GB, depending on what your findings are, its either that or pay for another editor.
Thank you in advance
Helen
Dear Hella Thank you for your response, I do not have any anti virus software running as far as I can see just windows defender. I have attached, task manager processes and performance, please bear in mind Team viewer is not normally running, I use this to connect to my PC when I am at work, so please discount this from your assessment. I am thinking of increasing the memory to 8GB, depending on what your findings are, its either that or pay for another editor. Thank you in advance Helen
Basics in Motion
Dear Support
I would appreciate it if you could look at my attached information. Thanks
Dear Support I would appreciate it if you could look at my attached information. Thanks
Basics in Motion
Basics in Motion posted this 04 April 2018
Dear Support
Can you please look at my attached information, I really could do with some advice on how to move forward with this?
Dear Support Can you please look at my attached information, I really could do with some advice on how to move forward with this? Thank you
Support Team posted this 04 April 2018
Our developers have looked into the screen shots and there is nothing strange there. Probably your computer is indeed a little bit old and some upgrade will be helpful.
In case that does not help, we can connect to you with TeamViewer and see if we could find any issues.
Hi, Our developers have looked into the screen shots and there is nothing strange there. Probably your computer is indeed a little bit old and some upgrade will be helpful. In case that does not help, we can connect to you with TeamViewer and see if we could find any issues. Sincerely, Hella
DouzanStudio
DouzanStudio posted this 04 April 2018
Hi, Helen!
The development within themler builder may not be fast as you think, So take a look at some tutorials of themler users in youtube and compare it to your experience, I've shared a couple of tutorials before in real time speed, check them out:
https://answers.themler.io/questions/137969/video-tutorial-making-a-fashion-layout-with-themler
Hi, Helen! The development within themler builder may not be fast as you think, So take a look at some tutorials of themler users in youtube and compare it to your experience, I've shared a couple of tutorials before in real time speed, check them out: https://answers.themler.io/questions/137969/video-tutorial-making-a-fashion-layout-with-themler
Basics in Motion
Dear Hella
Is it the size of the processor it is only 2.41Ghz?
Thanks Helen
Dear Hella Is it the size of the processor it is only 2.41Ghz? Thanks Helen
Basics in Motion
Dear DouzanStudio
Thank you for sharing your youtube tutorial, with regards to the speed this is at least 2 if not 3 times faster than mine.
Thanks Helen
Dear DouzanStudio Thank you for sharing your youtube tutorial, with regards to the speed this is at least 2 if not 3 times faster than mine. Thanks Helen
Support Team posted this 05 April 2018
It is probably memory or your HDD. Let us know if your hard drive is old or is not fast enough.
Hi, It is probably memory or your HDD. Let us know if your hard drive is old or is not fast enough. Sincerely, Hella
