HTML page linking problems in the footer
1157-619
1157-619 posted this 09 April 2018
Hello, it's about the html version. I have created main pages as well as sub-pages in the menu item "Home", e.g. "Sub Page 1". In the footer are links to the pages. The main page "Home" has the link "home.html", the subpage 1 in the footer "home/subpage1.html".
Now the problem:
As soon as I click in a subpage, the links in the footer no longer work.
Now the page "Home" links to "home/home.html" and the subpage 1 to "home/home/subpage1.html".
If the software did not put the subpages in a subfolder, then all links could be placed at the same level and everything would work.
How can the problem be solved? What settings are necessary in the software for it to work?
Here is the link to the demo page:
http://www.werk360.de/test/home.html
Hello, it's about the html version. I have created main pages as well as sub-pages in the menu item "Home", e.g. "Sub Page 1". In the footer are links to the pages. The main page "Home" has the link "home.html", the subpage 1 in the footer "home/subpage1.html". Now the problem: As soon as I click in a subpage, the links in the footer no longer work. Now the page "Home" links to "home/home.html" and the subpage 1 to "home/home/subpage1.html". If the software did not put the subpages in a subfolder, then all links could be placed at the same level and everything would work. How can the problem be solved? What settings are necessary in the software for it to work? Here is the link to the demo page: http://www.werk360.de/test/home.html
Support Team posted this 09 April 2018
Please try to use absolute links to pages. Alternatively, you may consider adding Vertical Menu into the Footer - the correct links will be created automatically.
Hello, Please try to use absolute links to pages. Alternatively, you may consider adding Vertical Menu into the Footer - the correct links will be created automatically. Sincerely, Nettie, BillionDigital Team
1157-619
Is Solution
Hello, it`s working with absolute links ! Thank you !
You are welcome! Please feel free to contact us if there are any other questions.
You are welcome! Please feel free to contact us if there are any other questions. Sincerely, Nettie, BillionDigital Team
