How to change Heading color using Hover?
info3139
info3139 posted this 2 weeks ago
Hi, Is there any possibility to change the heading color while hovering on Image? Please see the attached image for your better understanding.
http://e5e.0d8.myftpupload.com/ (Website URL)
Go to main feature section on home page and hover mouse on any or 1st image. The content will reveal as you hover, in the same time, the color should change to Blue of the heading "Privacy" in black.
Hi, Is there any possibility to change the heading color while hovering on Image? Please see the attached image for your better understanding. http://e5e.0d8.myftpupload.com/ (Website URL) Go to main feature section on home page and hover mouse on any or 1st image. The content will reveal as you hover, in the same time, the color should change to Blue of the heading "Privacy" in black.
6 Comments
You cannot apply the hover effect inside the application as those hoverboxes and the headings are not connected. I assume that it can be achieved only with the custom code. You can search for some solutions over the internet.
Hi, You cannot apply the hover effect inside the application as those hoverboxes and the headings are not connected. I assume that it can be achieved only with the custom code. You can search for some solutions over the internet. Sincerely, Hella
info3139
How can we do custom code in the Themler. As soon as we try to edit something, whole page gets converted into Post
What do you mean converted into post? Please provide more details and probably a screen shot of the issue.
The script code can be added under the Home >> Settings >> Additional HEAD HTML.
Hi, What do you mean converted into post? Please provide more details and probably a screen shot of the issue. The script code can be added under the Home >> Settings >> Additional HEAD HTML. Sincerely, Hella
info3139
Can you help me with the searching or provide the solution of Custom code? You are are the creator of Themler and would appreciate if that can happen with your support only. My project is on stake because of this pending feature. If it can;t be happen, my project will be cancelled.
> Hi, > > You cannot apply the hover effect inside the application as those hoverboxes and the headings are not connected. I assume that it can be achieved only with the custom code. You can search for some solutions over the internet. > > Sincerely, > Hella Can you help me with the searching or provide the solution of Custom code? You are are the creator of Themler and would appreciate if that can happen with your support only. My project is on stake because of this pending feature. If it can;t be happen, my project will be cancelled.
diamondhedgeusa
diamondhedgeusa posted this 2 weeks ago
thanks for information
Sorry, we provide support for the Themler features and do not support custom code modifications so we cannot help you in this matter.
Hi, Sorry, we provide support for the Themler features and do not support custom code modifications so we cannot help you in this matter. Sincerely, Hella
