Themler - template for PrestaShop
provaznik
provaznik posted this 11 April 2018
we have Themler v.441 and PrestaShop v. 1.7. I made a template for PrestaShop. I tried to install this template in Prestashop. I tried two ways how install the template.
The first way was: extensions - appearence - templates and logo - add a new template. Here was a mistake: This template is not compatible with PrestaShop 1.7.
The second way was: I used to Themler help (Hpw to Install PrestaShop Theme. You write: download Templae installer modul. But this modul is compatibility with v 1.3.0.0. - 1.5.6.3. And as I wrote we have PrestaShop v. 1.7.
How do we install the template? Do we install PrestaShop lower version for example 1.5? Or install template via FTP.
Thank you very much for your help.
Drahomira
Hello, we have Themler v.441 and PrestaShop v. 1.7. I made a template for PrestaShop. I tried to install this template in Prestashop. I tried two ways how install the template. The first way was: extensions - appearence - templates and logo - add a new template. Here was a mistake: This template is not compatible with PrestaShop 1.7. The second way was: I used to Themler help (Hpw to Install PrestaShop Theme. You write: download Templae installer modul. But this modul is compatibility with v 1.3.0.0. - 1.5.6.3. And as I wrote we have PrestaShop v. 1.7. How do we install the template? Do we install PrestaShop lower version for example 1.5? Or install template via FTP. Thank you very much for your help. Drahomira
8 Comments
Support Team posted this 11 April 2018
Hello Drahomira,
Please follow the steps from the article for Prestashop 1.7:
https://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version
Let us know if any questions appear in process.
Hello Drahomira, Please follow the steps from the article for Prestashop 1.7: https://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version Let us know if any questions appear in process. Sincerely, Nettie, BillionDigital Team
provaznik
Hello Nettie,
I tried it. It was my the first way. When I did it there is the mistake: This tepmape is not compatible with PrestaShop 1.7.
Drahomira
Hello Nettie, I tried it. It was my the first way. When I did it there is the mistake: This tepmape is not compatible with PrestaShop 1.7. Drahomira !PrestaShop.png!
provaznik
Hello Nettie,
I write only small note. I used the default template eShopper PrestaShop 1.6.0.8.
Drahomira
Hello Nettie, I write only small note. I used the default template eShopper PrestaShop 1.6.0.8. Drahomira
Support Team posted this 12 April 2018
PrestaShop 1.7 uses different framework. Therefore all PS 1.6 themes are not compatible with PS 1.7.
The PS 1.7 beta theme can be downloaded here:
http://themler.io/Download/PrestaShop17
Hi, PrestaShop 1.7 uses different framework. Therefore all PS 1.6 themes are not compatible with PS 1.7. The PS 1.7 beta theme can be downloaded here: http://themler.io/Download/PrestaShop17 Thank you, Olivia
provaznik
provaznik posted this 13 April 2018
thank you very much. But tgere is some another problem. When I upload the template into an application in Themler there is some error (see picture). If I open the template directly from e-shop (website) everything is OK. How can I open the templete in the application Themler?
Thank you, Drahomíra
Hello, thank you very much. But tgere is some another problem. When I upload the template into an application in Themler there is some error (see picture). If I open the template directly from e-shop (website) everything is OK. How can I open the templete in the application Themler? Thank you, Drahomíra!Error.png!
Support Team posted this 13 April 2018
In Themler desktop there is only Prestashop 1.6 available at the moment. You may work with Prestashop 1.7 either on your hosted website or at some localhost.
Hello, In Themler desktop there is only Prestashop 1.6 available at the moment. You may work with Prestashop 1.7 either on your hosted website or at some localhost. Sincerely, Nettie, BillionDigital Team
provaznik
I have the last question. Can you tell me when will be Themler desktop Prestashop 1.7?
Thanks, Drahomíra
Hi, I have the last question. Can you tell me when will be Themler desktop Prestashop 1.7? Thanks, Drahomíra
Hi Drahomíra,
Unfortunately there are no exact time frames for this at the moment, I can say that I will be included not in the near future. So please consider the ways mentioned above and let us know if any questions appear in process.
Hi Drahomíra, Unfortunately there are no exact time frames for this at the moment, I can say that I will be included not in the near future. So please consider the ways mentioned above and let us know if any questions appear in process. Sincerely, Nettie, BillionDigital Team
