How to make website content or whole theme responsive while creating website on Themler?
info3139
info3139 posted this 12 April 2018
Support Team posted this 12 April 2018
Actually the theme is responsive by the default. But in some cases it may look bad on the smaller screens when you use the absolute positioning, fixed width and height (in pixels), some fixed margins and padding. These options may cause the bad looking site on the phones. If you have any exact issue, please explain it in more details.
Hi, Actually the theme is responsive by the default. But in some cases it may look bad on the smaller screens when you use the absolute positioning, fixed width and height (in pixels), some fixed margins and padding. These options may cause the bad looking site on the phones. If you have any exact issue, please explain it in more details. Sincerely, Hella
info3139
Thank you for the detailed explanation. I have understood. If you remember I shared one picture with you yesterday asking to make heading active while on Hover.
Is there any possibility to make "Click on Heading" then Hover on image comes up. Actually i am not proficient in coding that's why I kept asking about the same
Thank you for the detailed explanation. I have understood. If you remember I shared one picture with you yesterday asking to make heading active while on Hover. Is there any possibility to make "Click on Heading" then Hover on image comes up. Actually i am not proficient in coding that's why I kept asking about the same
Support Team posted this 13 April 2018
I'm not sure how it can be created at all. As I said, we do not have any possibility to create such effect in the application. You have seen it on some live site? I assume that it uses custom JS code or some plug-in to implement such behavior. But we do not support such custom modifications.
Hi, I'm not sure how it can be created at all. As I said, we do not have any possibility to create such effect in the application. You have seen it on some live site? I assume that it uses custom JS code or some plug-in to implement such behavior. But we do not support such custom modifications. Sincerely, Hella
