Sub Menu items are Hidden behind Slider
info3139
info3139 posted this 18 April 2018
Sub Menu items are Hidden behind Slider. As soon as we scroll down, the sub menu starts showing.
11 Comments
Support Team posted this 18 April 2018
Could you please provide a link to the page that demonstrates the issue?
If the Menu is inside the Header and Slider is outside the Header please try the following solution:
This may help.
Hi, Could you please provide a link to the page that demonstrates the issue? If the Menu is inside the Header and Slider is outside the Header please try the following solution: !header-z-index.png! This may help. Thank you, Olivia
info3139
This is the URL www.ams-ship.com
info3139
Started Working now. Thank you so much :)
Nice to hear that. Feel free to contact us in any other occasion.
Hi, Nice to hear that. Feel free to contact us in any other occasion. Sincerely, Hella
info3139
Hi Hella,
Please visit this site https://devicemockupswp.com/scrolling/ and I want to use the same feature in my website which I am making from Themler. It is not coming directly by copying and pasting shortcode. What other things I need to do?
> Hi, > > Nice to hear that. Feel free to contact us in any other occasion. > > Sincerely, > Hella Hi Hella, Please visit this site https://devicemockupswp.com/scrolling/ and I want to use the same feature in my website which I am making from Themler. It is not coming directly by copying and pasting shortcode. What other things I need to do?
Looks like this shortcode can be used after the corresponding plug-ins installed. Have you installed the https://wordpress.org/plugins/device-mockups/ plug-in on your site?
Hi, Looks like this shortcode can be used after the corresponding plug-ins installed. Have you installed the https://wordpress.org/plugins/device-mockups/ plug-in on your site? Sincerely, Hella
info3139
I have installed the plugin already and after copying and pasting the shortcode given this is what I am getting https://ams-ship.com/sample-page/. Just the code showing
> Hi, > > Looks like this shortcode can be used after the corresponding plug-ins installed. Have you installed the https://wordpress.org/plugins/device-mockups/ plug-in on your site? > > Sincerely, > Hella I have installed the plugin already and after copying and pasting the shortcode given this is what I am getting https://ams-ship.com/sample-page/. Just the code showing
Have you used the Shortcode control inside Themler for that? And does it work with the default WP theme?
Hi, Have you used the Shortcode control inside Themler for that? And does it work with the default WP theme? Sincerely, Hella
info3139
Yes that is working well using the Themler shortcode. Thanks a lot.
Tell me where I can find the coding of this as the CMS page has converted into Template Page after putting shortcode from themler?
Yes that is working well using the Themler shortcode. Thanks a lot. Tell me where I can find the coding of this as the CMS page has converted into Template Page after putting shortcode from themler?
info3139
info3139 posted this 19 April 2018
Hi Hella,
Can I run themler on my HMTL website which is already live? We did not design that layout using Themler but I want to build new page only to connect to the existing layout as Portfolio Page.
> Hi, > > Nice to hear that. Feel free to contact us in any other occasion. > > Sincerely, > Hella Hi Hella, Can I run themler on my HMTL website which is already live? We did not design that layout using Themler but I want to build new page only to connect to the existing layout as Portfolio Page.
Support Team posted this 20 April 2018
Unfortunately this question is not quite clear to me. Themler does not create content pages. It displays existing WP pages and posts. If you ant to add this shortcode into the content of some page or post you can do it in the WP editor. Themler Shortcode control cannot be inserted into the green content area because this area is a shortcode generator.
If you added Shortcode control into the blue template area then this control is a part of the template (Page or Post, probably) and it will be displayed on all pages which use this template.
Themler can work with a Themler generated websites only. But as alternative you can try to create a small website with one page in Themler and create a link from old website to the new small Themler website. But this will a separate website with own style, script and html files.
Hello, > Tell me where I can find the coding of this as the CMS page has converted into Template Page after putting shortcode from themler? Unfortunately this question is not quite clear to me. Themler does not create content pages. It displays existing WP pages and posts. If you ant to add this shortcode into the content of some page or post you can do it in the WP editor. Themler Shortcode control cannot be inserted into the green content area because this area is a shortcode generator. If you added Shortcode control into the blue template area then this control is a part of the template (Page or Post, probably) and it will be displayed on all pages which use this template. > Can I run themler on my HMTL website which is already live? We did not design that layout using Themler but I want to build new page only to connect to the existing layout as Portfolio Page. Themler can work with a Themler generated websites only. But as alternative you can try to create a small website with one page in Themler and create a link from old website to the new small Themler website. But this will a separate website with own style, script and html files. Thank you, Olivia
