Themler 502 error
Tafy
Tafy posted this 23 April 2018
Hi Getting error below when trying to save or refresh themes.
502 - Web server received an invalid response while acting as a gateway or proxy server.
There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server.
Hi Getting error below when trying to save or refresh themes. 502 - Web server received an invalid response while acting as a gateway or proxy server. There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server.
23 Comments
Support Team posted this 23 April 2018
Thanks for reporting the issue. Our developers are working at it and will fix it as soon as possible.
Hello, Thanks for reporting the issue. Our developers are working at it and will fix it as soon as possible. Sincerely, Nettie, BillionDigital Team
em es
em es posted this 23 April 2018
Same here... Error when I try to save.
em es,
We are sorry for the issue and will let you know when it is fixed. Thank you for your patience.
**em es**, We are sorry for the issue and will let you know when it is fixed. Thank you for your patience. Sincerely, Nettie, BillionDigital Team
akrisanov
akrisanov posted this 23 April 2018
Is it linked with Telegram ban?
Can proxy or VPN solve the issue?
Is it linked with Telegram ban? Can proxy or VPN solve the issue?
em es
No
> Is it linked with Telegram ban? > Can proxy or VPN solve the issue? No
The issue has nothing to do with proxy or VPN, or Telegram. It can be related to the old Themler version used. It refers to the old themler.com domain name themler.com. This domain has has SSL certificate expired. We will try to extend the sertificate for some time. Still it is recommended to update the theme to the latest version that uses themler.io domain since a while ago.
Hello, The issue has nothing to do with proxy or VPN, or Telegram. It can be related to the old Themler version used. It refers to the old themler.com domain name themler.com. This domain has has SSL certificate expired. We will try to extend the sertificate for some time. Still it is recommended to update the theme to the latest version that uses themler.io domain since a while ago. Sincerely, Nettie, BillionDigital Team
akrisanov
I'm using 328 version. If I update it will the update go painlessly?
There should be no issues. Also, as a rule, a backup is created before updating theme. However you may also create a theme backup manually just in case. Let us know if still any issues appear in process.
Hello, There should be no issues. Also, as a rule, a backup is created before updating theme. However you may also create a theme backup manually just in case. Let us know if still any issues appear in process. Sincerely, Nettie, BillionDigital Team
em es
TO be honest is some kind of joke that so big company as yours doesn`t care and forget to extend SSL. It should be basic thing for you.
> This domain has has SSL certificate expired. We will try to extend the sertificate for some time. TO be honest is some kind of joke that so big company as yours doesn`t care and forget to extend SSL. It should be basic thing for you.
The fact is that we use another domain for quite a some time - themler.io. The old one can be referred to in rather old themes only.
Hello, The fact is that we use another domain for quite a some time - themler.io. The old one can be referred to in rather old themes only. Sincerely, Nettie, BillionDigital Team
info1938
info1938 posted this 23 July 2018
Hi.
Having the same problem at the moment!
Can you , please, fix it ?
Hi. Having the same problem at the moment! Can you , please, fix it ?
info1938
Here's a screenshot.
Please, fix it as soon as it is possible.
Here's a screenshot. Please, fix it as soon as it is possible.
Support Team posted this 23 July 2018
We will fix the issue as soon as possible. We are sorry for the temporary inconvenience.
Hello, We will fix the issue as soon as possible. We are sorry for the temporary inconvenience. Sincerely, Nettie, BillionDigital Team
mz.musical
mz.musical posted this 23 July 2018
I also have the server error 502.!
Please inform us here after the problem is solved.
I also have the server error 502.! Please inform us here after the problem is solved.
Sure, we will let you know as soon as the issue is fixed.
Hello, Sure, we will let you know as soon as the issue is fixed. Sincerely, Nettie, BillionDigital Team
Support Team posted this 24 July 2018
The issue is fixed, all themes including old themes should be opened, logged in and saved without any issues now. It may be needed to clear cache. Let us know in case you have any with any of the themes.
Hello, The issue is fixed, all themes including old themes should be opened, logged in and saved without any issues now. It may be needed to clear cache. Let us know in case you have any with any of the themes. Sincerely, Nettie, BillionDigital Team
fngatia
fngatia posted this 21 December 2018
Am having this issue right now. Its emergency please help!
Error Description: 502 - Web server received an invalid response while acting as a gateway or proxy server.
Version 379
Am having this issue right now. Its emergency please help! Error Description: 502 - Web server received an invalid response while acting as a gateway or proxy server. There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server. Version 379
Support Team posted this 21 December 2018
The problem has been fixed. Can you please try now
goncharov2
goncharov2 posted this 21 December 2018
Today, my topic stopped working, and after the restart, the program began to hang when choosing WordPress.
If you run as html, then you can not enter the login window. I get an error 502 and a link to the domain themler.com. Bought and installed from the site a few days ago.
Today, my topic stopped working, and after the restart, the program began to hang when choosing WordPress. If you run as html, then you can not enter the login window. I get an error 502 and a link to the domain themler.com. Bought and installed from the site a few days ago.
FAGE
FAGE posted this 24 December 2018
the problem still continues
themler 502 - Web server received an invalid response while acting as a gateway or proxy server
the problem still continues themler 502 - Web server received an invalid response while acting as a gateway or proxy server
