How to Remove Space Between Footer & Pre-Footer
info3139
info3139 posted this 4 weeks ago
Hi Hella,
I haven't set any Margin or Padding or Space between Footer & Prefooter but sometimes when page is getting re-load the space is being created automatically and after refreshing again, the Space is gone. Please suggest the permanent solution as I don't want any space between. See the attached Images while Opening the website then refresh the page.
This is the URL http://e5e.0d8.myftpupload.com
Hi Hella, I haven't set any Margin or Padding or Space between Footer & Prefooter but sometimes when page is getting re-load the space is being created automatically and after refreshing again, the Space is gone. Please suggest the permanent solution as I don't want any space between. See the attached Images while Opening the website then refresh the page. This is the URL http://e5e.0d8.myftpupload.com
8 Comments
Please try to add the following code under the Home >> Settings >> Additional CSS:
.separated-item-25 {
    min-height: 200px!important;
Hi, Please try to add the following code under the Home >> Settings >> Additional CSS: .separated-item-25 { min-height: 200px!important; } Sincerely, Hella
info3139
Hi Hella,
That worked well :) Thank you!
Tell me one more thing, Can we use visual composer with Themler? There are certain functionality which we need to develop and unable to do it from Themler?
> Hi, > > Please try to add the following code under the Home >> Settings >> Additional CSS: > > .separated-item-25 { > min-height: 200px!important; > } > > Sincerely, > Hella Hi Hella, That worked well :) Thank you! Tell me one more thing, Can we use visual composer with Themler? There are certain functionality which we need to develop and unable to do it from Themler?
You can use Visual Composer to add the content from WP admin. It should take the theme styles. But we cannot guarantee that there will be no conflicts in some particular situations. In any case, looks like some our users are using Visual Composer on their sites.
Hi, You can use Visual Composer to add the content from WP admin. It should take the theme styles. But we cannot guarantee that there will be no conflicts in some particular situations. In any case, looks like some our users are using Visual Composer on their sites. Sincerely, Hella
info3139
info3139 posted this 3 weeks ago
Hi Hella,
I have put additional CSS recommended by you to Remove Space Between Footer & Pre-Footer. It worked for Home Page only but the minor space is still left in inner pages as well.
Check these pages
http://e5e.0d8.myftpupload.com/product/
http://e5e.0d8.myftpupload.com/contact-us/
Hi Hella, I have put additional CSS recommended by you to Remove Space Between Footer & Pre-Footer. It worked for Home Page only but the minor space is still left in inner pages as well. Check these pages http://e5e.0d8.myftpupload.com/product/ http://e5e.0d8.myftpupload.com/contact-us/
Try to use this code instead:
.separated-grid.row > div {
Hi, Try to use this code instead: .separated-grid.row > div { min-height: 200px!important; } Sincerely, Hella
info3139
Yes, That worked out well :)
Thank you so much
> Hi, > > Try to use this code instead: > > .separated-grid.row > div { > min-height: 200px!important; > } > > Sincerely, > Hella Yes, That worked out well :) Thank you so much
info3139
How to get the Menu Bar in the Middle in Tablet & Mobile Mode?
switch to the tablet mode and use the positioning options to center the menu. If that does not help, provide an access to the site back end.
Hi, switch to the tablet mode and use the positioning options to center the menu. If that does not help, provide an access to the site back end. Sincerely, Hella
