Importing a Joomla design from Artiseer
richard.gate
richard.gate posted this 4 weeks ago
When will this be available?
22 Comments
Hi Richard,
It is already possible since 2015 :)
Please have a look at the following article.
http://answers.themler.io/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015
Ivan
Hi Richard, It is already possible since 2015 :) Please have a look at the following article. http://answers.themler.io/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 Thanks, Ivan
richard.gate
That article is rather confused. it says "You can finally import Joomla Artisteer projects directly into Themler." BUT then only talks about exporting from Themler.
richard.gate
If I try to Import an ARTX file type its just says "File upload failed, unknown archive type".
Please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version:
Hello, Please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie, BillionDigital Team
richard.gate
Are you telling me this only works on the Windows version?
Yes, this version is for Artisteer for Windows. If you have no possibility to use this version let us know so htat we export your theme to Themler for you.
Hello, Yes, this version is for Artisteer for Windows. If you have no possibility to use this version let us know so htat we export your theme to Themler for you. Sincerely, Nettie, BillionDigital Team
richard.gate
So back to my original question - "When will this be available in the MAC version?"
Sorry but we do not plan to issue a new Artisteer for Mac version in the near future. You may consider installing Artisteer latest version for Windows on a virtual machine - or let us know so that we could export the theme to Themler for you, as suggested above.
Hello, Sorry but we do not plan to issue a new Artisteer for Mac version in the near future. You may consider installing Artisteer latest version for Windows on a virtual machine - or let us know so that we could export the theme to Themler for you, as suggested above. Sincerely, Nettie, BillionDigital Team
richard.gate
I was asking about Themler !!
Themler for Mac is available at http://themler.io/download. Besides, you may install and use Themler theme on your hosted website or localhost in different OS.
Hello, Themler for Mac is available at http://themler.io/download. Besides, you may install and use Themler theme on your hosted website or localhost in different OS. Sincerely, Nettie, BillionDigital Team
richard.gate
Why are you ignoring my question?. I'll ask it again and see if you can answer this time....
"When will the ability to import Artisteer created Joomla themes be available in Themler for MAC?"
Why are you ignoring my question?. I'll ask it again and see if you can answer this time.... "When will the ability to import Artisteer created Joomla themes be available in Themler for MAC?"
The theme exported from the mentioned Artisteer latest version can be imported both in Themler for Windows or Themler for Mac.
Hello, The theme exported from the mentioned Artisteer latest version can be imported both in Themler for Windows or Themler for Mac. Sincerely, Nettie, BillionDigital Team
richard.gate
So to be clear, you say that the current Themler for MAC can import Artisteer ARTX files?
No, projects in .artx format cannot be imported in Themler right away. I'll explain it in steps. To import Artisteer theme for Mac, you need to:
1. Open your .artx project in the latest Artisteer version (I have mentioned before) and select export type "Themler for Joomla", export the theme.
2. You will get the theme .zip ready for import into Themler. In Themler choose File >> Import from Zip and import this theme.
Hello, No, projects in .artx format cannot be imported in Themler right away. I'll explain it in steps. To import Artisteer theme for Mac, you need to: 1. Open your .artx project in the latest Artisteer version (I have mentioned before) and select export type "Themler for Joomla", export the theme. 2. You will get the theme .zip ready for import into Themler. In Themler choose File >> Import from Zip and import this theme. Sincerely, Nettie, BillionDigital Team
richard.gate
OK now let me explain why that makes me dislike your products....
I have the most recent version of Artisteer from MAC.
The Theme I'm working on in Artistieer does not work correctly in Joomla 3.8.7
So then I realised Artisteer from MAC has not been updated in 3 year.
Then I looked for another tool and found Themler.
Themler is promoted as being able to import Artisteer files.
Turns out it the MAC version does not import Artisteer files.
Now I'm told I have to upgrade Artisteer, which would have to be a Windows version, before I can load the theme into Themler.
So having purchased Themler I also have to pay from a Windows version upgrade for Artistieer.
Have any better suggestions?
OK now let me explain why that makes me dislike your products.... I have the most recent version of Artisteer from MAC. The Theme I'm working on in Artistieer does not work correctly in Joomla 3.8.7 So then I realised Artisteer from MAC has not been updated in 3 year. Then I looked for another tool and found Themler. Themler is promoted as being able to import Artisteer files. Turns out it the MAC version does not import Artisteer files. Now I'm told I have to upgrade Artisteer, which would have to be a Windows version, before I can load the theme into Themler. So having purchased Themler I also have to pay from a Windows version upgrade for Artistieer. Have any better suggestions?
With Themler you get extension of your current Artisteer license for free. We have extended your Artisteer license to April 25, 2019.
Hello, With Themler you get extension of your current Artisteer license for free. We have extended your Artisteer license to April 25, 2019. Sincerely, Nettie, BillionDigital Team
richard.gate
OK so I have installed Artisteer 4.3.0.60745 on Windows, loaded my old Template, saved and exported it for Joomla.
However, on Joomla it looks nothing like it looked on Artisteer. Is Joomla 3.8.7 supported?
OK so I have installed Artisteer 4.3.0.60745 on Windows, loaded my old Template, saved and exported it for Joomla. However, on Joomla it looks nothing like it looked on Artisteer. Is Joomla 3.8.7 supported?
It will not be exactly the same, as Themler theme has different structure. Still the version I have provided link to above (...928) have several issues fixed for Themler for Joomla version, so I would rather recommend to re-export with this version. Yes, Themler should support the newest Joomla versions including 3.8.7.
Sincerely
Hello, It will not be exactly the same, as Themler theme has different structure. Still the version I have provided link to above (...928) have several issues fixed for Themler for Joomla version, so I would rather recommend to re-export with this version. Yes, Themler should support the newest Joomla versions including 3.8.7. Sincerely Nettie, BillionDigital Team
richard.gate
I think you misread my posts again. I was talking about Artisteer this time !!
And please could you not us words like "should" it either does or it does not !!
I think you misread my posts again. I was talking about Artisteer this time !! And please could you not us words like "should" it either does or it does not !!
What exactly is missing when your export the theme from Artisteer and install in Joomla? Some screenshots would be helpful.
Hello, What exactly is missing when your export the theme from Artisteer and install in Joomla? Some screenshots would be helpful. Sincerely, Nettie, BillionDigital Team
