Prestashop Cart Ajax
CalamarsCompany!
CalamarsCompany! posted this 4 weeks ago
The problem that I have in the theme created with Themler is that when an user adds a product to the cart the ajax popup asking if the user wants to continue shopping or go to checkout is not showing:
http://palomacabadas.com/es/best-sellers/75-libro-10-sindrome-de-extraterrestre-edicion-2017.html
I have checked the module "cart block" the "Ajax cart" option is set to yes
In Preferences > Modules, the option "rRedirect after adding product to cart" is set in "Cart Summary"
Prestashop 1.6.1.18
Thanks in advance
Hello, The problem that I have in the theme created with Themler is that when an user adds a product to the cart the ajax popup asking if the user wants to continue shopping or go to checkout is not showing: http://palomacabadas.com/es/best-sellers/75-libro-10-sindrome-de-extraterrestre-edicion-2017.html I have checked the module "cart block" the "Ajax cart" option is set to yes In Preferences > Modules, the option "rRedirect after adding product to cart" is set in "Cart Summary" Prestashop 1.6.1.18 Thanks in advance
11 Comments
It is supposed to work as following with Themler theme: when Ajax cart is enabled and you add a product to the cart, the button text changes to "Added" without navigating to the Shopping cart page. Let us know if it doesn't work in this way.
Hello, It is supposed to work as following with Themler theme: when Ajax cart is enabled and you add a product to the cart, the button text changes to "Added" without navigating to the Shopping cart page. Let us know if it doesn't work in this way. Sincerely, Nettie, BillionDigital Team
CalamarsCompany!
CalamarsCompany! posted this 3 weeks ago
Yes, it is how it works, but I want to show the ajax pop up asking to the customer to continue shopping or go to check out. How can I do that?
Best regards,
Hello, Yes, it is how it works, but I want to show the ajax pop up asking to the customer to continue shopping or go to check out. How can I do that? Best regards,
Unfortunately, Themler Add to Cart button does not support this Prestashop pop-up.
Hello, Unfortunately, Themler Add to Cart button does not support this Prestashop pop-up. Sincerely, Nettie, BillionDigital Team
CalamarsCompany!
So,
Do I lose this functionality in prestashop?
I think that this is important in an e-ccommerce. Some other solution?
So, Do I lose this functionality in prestashop? I think that this is important in an e-ccommerce. Some other solution?
Theoretically, you may try replacing Themler Add to Cart button with the Prestashop built-in code for the Add to Cart button inside the CMS Code control if you know the code. Unfortunately, it looks like there are no other solutions.
Hello, Theoretically, you may try replacing Themler Add to Cart button with the Prestashop built-in code for the Add to Cart button inside the CMS Code control if you know the code. Unfortunately, it looks like there are no other solutions. Sincerely, Nettie, BillionDigital Team
CalamarsCompany!
OK Nettie,
This was our second option, but, I suggest includes this function in themler. It is very important!
OK Nettie, This was our second option, but, I suggest includes this function in themler. It is very important! Thank you,
I see. Sorry for this inconvenience. We'll keep it in our wishlist for future implementation, if this becomes technically possible.
Hello, I see. Sorry for this inconvenience. We'll keep it in our wishlist for future implementation, if this becomes technically possible. Sincerely, Nettie, BillionDigital Team
Linkebel
Linkebel posted this 2 weeks ago
here is the solution I used before stopping Themeler,
I hope it still works
CSS
------- In Themeler Additional CSS
.black_overlay{
        display: none;
        position: absolute;
        top: 0%;
        left: 0%;
        width: 100%;
        height: 100%;
        background-color: black;
        z-index:1001;
        -moz-opacity: 0.8;
        opacity:.80;
        filter: alpha(opacity=80);
.white_content {
        display: none;
        position: fixed;
        top: 25%;
        left: 25%;
        width: 50%;
        height: 30%;
        padding: 16px;
        border: 16px solid #006637;
        background-color: white;
        z-index:1002;
        overflow: auto;
                text-align: center;
PopUp
--------- In Additional head html (add bloc html in the header)
<div id="light" class="white_content"><br><br>Le produit a ÈtÈ ajoutÈ ‡ votre panier.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Continuer mes achats</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Aller au panier</a></div>
        <div id="fade" class="black_overlay"></div>
--------- several language
{if $lang_iso == fr}
{/if}
{if $lang_iso == en}
<div id="light" class="white_content"><br><br>Product was successfully added to your shopping cart.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Shopping</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Checkout</a></div>
{/if}
{if $lang_iso == nl}
{/if}
in template
-------- Edit- product-list.tpl
-------- search "add to cart"
onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'"
----- exemple ligne 461 product-list.tpl
<a class=" bd-productbuy-5 bd-button button ajax_add_to_cart_button btn btn-default" href="{$link->getPageLink('cart',false, NULL, "add=1&amp;id_product={$product.id_product|intval}&amp;token={$static_token}", false)|escape:'html':'UTF-8'}" rel="ajax_id_product_{$product.id_product|intval}" title="{l s='Add to cart'}" data-id-product="{$product.id_product|intval}" onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'">
Hi, here is the solution I used before stopping Themeler, I hope it still works CSS --- ------- In Themeler Additional CSS .black_overlay{ display: none; position: absolute; top: 0%; left: 0%; width: 100%; height: 100%; background-color: black; z-index:1001; -moz-opacity: 0.8; opacity:.80; filter: alpha(opacity=80); } .white_content { display: none; position: fixed; top: 25%; left: 25%; width: 50%; height: 30%; padding: 16px; border: 16px solid #006637; background-color: white; z-index:1002; overflow: auto; text-align: center; } PopUp -------- --------- In Additional head html (add bloc html in the header) <div id="light" class="white_content"><br><br>Le produit a ÈtÈ ajoutÈ ‡ votre panier.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Continuer mes achats</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Aller au panier</a></div> <div id="fade" class="black_overlay"></div> --------- several language {if $lang_iso == fr} <div id="light" class="white_content"><br><br>Le produit a ÈtÈ ajoutÈ ‡ votre panier.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Continuer mes achats</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Aller au panier</a></div> <div id="fade" class="black_overlay"></div> {/if} {if $lang_iso == en} <div id="light" class="white_content"><br><br>Product was successfully added to your shopping cart.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Shopping</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Checkout</a></div> <div id="fade" class="black_overlay"></div> {/if} {if $lang_iso == nl} <div id="light" class="white_content"><br><br>Product was successfully added to your shopping cart.<br><br><a href="javascript:void(0)" onclick="document.getElementById('light').style.display='none';document.getElementById('fade').style.display='none'" class="bd-button">Shopping</a> <a href="http://shop.bioshanti.be/fr/commande" class="bd-button">Checkout</a></div> <div id="fade" class="black_overlay"></div> {/if} in template ------------- -------- Edit- product-list.tpl -------- search "add to cart" onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'" ----- exemple ligne 461 product-list.tpl <a class=" bd-productbuy-5 bd-button button ajax_add_to_cart_button btn btn-default" href="{$link->getPageLink('cart',false, NULL, "add=1&amp;id_product={$product.id_product|intval}&amp;token={$static_token}", false)|escape:'html':'UTF-8'}" rel="ajax_id_product_{$product.id_product|intval}" title="{l s='Add to cart'}" data-id-product="{$product.id_product|intval}" onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'">
CalamarsCompany!
CalamarsCompany! posted this 2 weeks ago
Hello Linkebel,
Thank you very much for your help. Yout code is working perfectly!!
Now I need the pop up in the product detail template not only in product-list.tpl. I have tried adding the code:
in file product.tpl, but it is not working. Any idea?
Best regards,
Hello Linkebel, Thank you very much for your help. Yout code is working perfectly!! Now I need the pop up in the product detail template not only in product-list.tpl. I have tried adding the code: onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'" in file product.tpl, but it is not working. Any idea? Best regards,
Linkebel
Unfortunately I no longer use either Themler or Prestashop (now Wordpess with Woocommerce and template Divi)
I can not test and help you.
But at first glance I would have put that in product.tpl, but be careful because in my memory there are 2 links to edit and if you do only 1 of 2 it will not work.
If it does not always work, I advise you to download all the folder themes in your computer, you open the file with a code editor like Brackets and you do a search in all the files of "add to cart" and you should have all the files that use the link, you do some testing and you should find the right link.
Good luck.
Unfortunately I no longer use either Themler or Prestashop (now Wordpess with Woocommerce and template Divi) I can not test and help you. But at first glance I would have put that in product.tpl, but be careful because in my memory there are 2 links to edit and if you do only 1 of 2 it will not work. If it does not always work, I advise you to download all the folder themes in your computer, you open the file with a code editor like Brackets and you do a search in all the files of "add to cart" and you should have all the files that use the link, you do some testing and you should find the right link. Good luck.
CalamarsCompany!
Thanks again. I could do it:
  • Edit the product.tpl (in my case I had a second product.tpl inside "includes" folder in the Thembler template)
  • Search the &lt;input&gt; tag related with the "Add to cart" button.
  • add onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'". You will have something like:
&lt;input type name value class&gt;
Thanks for your help and best regards,
Hi, Thanks again. I could do it: - Edit the product.tpl (in my case I had a second product.tpl inside "includes" folder in the Thembler template) - Search the `&lt;input&gt;` tag related with the "Add to cart" button. - add onclick="document.getElementById('light').style.display='block';document.getElementById('fade').style.display='block'". You will have something like: `&lt;input type name value class&gt;` Thanks for your help and best regards,
