Slow changes edit for Wordpress in Desktop
azulmercedes
azulmercedes posted this 4 weeks ago
Hello Guys,
I have been using Themler for almost a year, but I am very dissatisfied with the fact that many of the edits I make to the temple ─ even just with just two (2) sections for a WordPress Homepage, takes more than one minute or two.
The fact that just change position or color in a object takes more than a minute is driven me crazy and at the end the overall time to create a template as I am looking for takes several hours.
Please, can you let me know if you have a troubleshooting flow to detect what settings in my system should I modify to improve the editing in Themler?
I hope get news from you soon.
Best
Juan.
Hello Guys, I have been using Themler for almost a year, but I am very dissatisfied with the fact that many of the edits I make to the temple ─ even just with just two (2) sections for a WordPress Homepage, takes more than one minute or two. The fact that just change position or color in a object takes more than a minute is driven me crazy and at the end the overall time to create a template as I am looking for takes several hours. Please, can you let me know if you have a troubleshooting flow to detect what settings in my system should I modify to improve the editing in Themler? I hope get news from you soon. Best Juan.
I see some logs from your account with the slow performance. That may be caused by the anti virus applications and firewall. Also if some other heavy processes are run along with Themler. Maybe your computer characteristics are not fast enough or your hard drive is a bit slow.
Try to disable anti virus application first to see if that helps.
Hi, I see some logs from your account with the slow performance. That may be caused by the anti virus applications and firewall. Also if some other heavy processes are run along with Themler. Maybe your computer characteristics are not fast enough or your hard drive is a bit slow. Try to disable anti virus application first to see if that helps. Sincerely, Hella
azulmercedes
azulmercedes posted this 3 weeks ago
Dear Hella,
I see a little difference in performance, I have a 8 core PC with 16 GB RAM, so I think is important to set exclusions in my antivirus. Can you let me know the path of files in order to set in my antivirus in order to improve performance?
Best
> Hi, > > I see some logs from your account with the slow performance. That may be caused by the anti virus applications and firewall. Also if some other heavy processes are run along with Themler. Maybe your computer characteristics are not fast enough or your hard drive is a bit slow. > Try to disable anti virus application first to see if that helps. > > Sincerely, > Hella Dear Hella, I see a little difference in performance, I have a 8 core PC with 16 GB RAM, so I think is important to set exclusions in my antivirus. Can you let me know the path of files in order to set in my antivirus in order to improve performance? Best
Basics in Motion
Basics in Motion posted this 3 weeks ago
I Have the same problem, if you look at your task master the performance section Themler uses 5 google chromes and a heck of a lot of memory . . . I understand your frustration
Hi I Have the same problem, if you look at your task master the performance section Themler uses 5 google chromes and a heck of a lot of memory . . . I understand your frustration
azulmercedes
I hope they post a slution soon.
With the information provided I hope they mention which paths should be excluded in Antivirus to improve performance a little.
As fas I have seen, beside the Chrome instances, there's also a local Apache Server running, and I doubt set exclusions for the whole Themler package will be an easy task.
Good luck for you too Basics in Motion.
Best
> Hi > I Have the same problem, if you look at your task master the performance section Themler uses 5 google chromes and a heck of a lot of memory . . . I understand your frustration I hope they post a slution soon. With the information provided I hope they mention which paths should be excluded in Antivirus to improve performance a little. As fas I have seen, beside the Chrome instances, there's also a local Apache Server running, and I doubt set exclusions for the whole Themler package will be an easy task. Good luck for you too Basics in Motion. Best
