woocommerce pagination >> new page shows always the bottom of the page instad starting on the top
RANZI
RANZI posted this 04 May 2018
i am using themler theme for woocommerce. On the produkts pagination, i cannot find an option to set the next page loding /visible on the top of the page.
Can you kindly give me support how to find a solution.
Thank you.
Hello, i am using themler theme for woocommerce. On the produkts pagination, i cannot find an option to set the next page loding /visible on the top of the page. Can you kindly give me support how to find a solution. Thank you.
Support Team posted this 07 May 2018
Do you mean Product Pagination on the products Template? There is a separate control for this on the Header Bar:
You can add it on top of the products grid.
Hi, Do you mean Product Pagination on the products Template? There is a separate control for this on the Header Bar: !product-pagination.png! You can add it on top of the products grid. Thank you, Olivia
RANZI
RANZI posted this 07 May 2018
Dear Olivia
sorry. what I meant is:
when using/klicking the next page on product pagination , the next page does not start at the beginning of the page - on the top as usualy i wanted it - it starts at the Bottom. so the user has to scoll manually to the top to see the next products
( have a look please at www.ranzi.com/de/shop)
enter link description here
Dear Olivia sorry. what I meant is: when using/klicking the next page on product pagination , the next page does not start at the beginning of the page - on the top as usualy i wanted it - it starts at the Bottom. so the user has to scoll manually to the top to see the next products ( have a look please at www.ranzi.com/de/shop) [enter link description here][1] [1]: http://www.ranzi.com
Themler does not control this. I assume that the WP plug-in is responsible for the way the content of the shop is loaded and how the page works then. So if using the non-Themler theme it might be working the same.
Hi, Themler does not control this. I assume that the WP plug-in is responsible for the way the content of the shop is loaded and how the page works then. So if using the non-Themler theme it might be working the same. Sincerely, Hella
