White space content - footer
christophe39
christophe39 posted this 04 May 2018
I have a white space which is present 1 time on 5 at the bottom of page between my contents and my footer.
I do not find the solution to solve the problem. You can help me.
Website : http://www.at-elierdev.be/yellow2/
Thank-you
Christophe
Hello, I have a white space which is present 1 time on 5 at the bottom of page between my contents and my footer. I do not find the solution to solve the problem. You can help me. Website : http://www.at-elierdev.be/yellow2/ Thank-you Christophe
Support Team posted this 05 May 2018
Hello Christophe,
I have checked your site in two browsers, resized it, but still couldn't see white space above the footer. Do you see it in a particular resolution or browser?
Gina,
Hello Christophe, I have checked your site in two browsers, resized it, but still couldn't see white space above the footer. Do you see it in a particular resolution or browser? Sincerely, Gina, Themler Support
christophe39
christophe39 posted this 05 May 2018
The problem is always very present, look at the video as attachment
http://www.at-elierdev.be/themler/Themler.mp4
Christophe
Hello, The problem is always very present, look at the video as attachment http://www.at-elierdev.be/themler/Themler.mp4 Christophe
Support Team posted this 07 May 2018
Try to add this code under the Home >> Settings >> Additional CSS:
.separated-item-25 {
    min-height: 200px!important;
The problem appears some times when using Visual Composer for the site content and the Stretch to Bottom extension in Themler. Then Themler does not get the content height value correctly and it causes such gap.
Hi, Try to add this code under the Home >> Settings >> Additional CSS: .separated-item-25 { min-height: 200px!important; } The problem appears some times when using Visual Composer for the site content and the Stretch to Bottom extension in Themler. Then Themler does not get the content height value correctly and it causes such gap. Sincerely, Hella
