Google Tag Manager _ WP functions.php
denisp
denisp posted this 04 May 2018
I'd like to know about functions.php on WP theme.
I have found, at the end of the file, the snippet code for Google Tag Manager (GTM).
If I customise this code with my GTM ID, then will I loose my customisation
if I modify / update my theme via themler?
thanks in advance
denis
Hello, I'd like to know about functions.php on WP theme. I have found, at the end of the file, the snippet code for Google Tag Manager (GTM). If I customise this code with my GTM ID, then will I loose my customisation if I modify / update my theme via themler? thanks in advance denis
Support Team posted this 04 May 2018
Most probably functions.php file will indeed be overwritten after any saved alternation in Themler.
However, to know it for sure you can try doing it once.
Ivan
Hi, Most probably `functions.php` file will indeed be overwritten after any saved alternation in Themler. However, to know it for sure you can try doing it once. Please let us know if you have any further questions. Thanks, Ivan
