How to enable keyboard navigation?
biuro90
biuro90 posted this 08 May 2018
How to enable keyboard navigation my site? (PgUp, PgDn, Up, Dn)
9 Comments
Support Team posted this 08 May 2018
The keyboard scrolling should be working by the default. If it does not work on your page, please try disabling all the site plug-ins and also the browser plug-ins if there are any.
Hi, The keyboard scrolling should be working by the default. If it does not work on your page, please try disabling all the site plug-ins and also the browser plug-ins if there are any. Sincerely, Hella
biuro90
It is rather a template's fault. When I changed the template to the default Joomla, the keyboard navigation works correctly.
Please help.
It is rather a template's fault. When I changed the template to the default Joomla, the keyboard navigation works correctly. Please help.
Please provide a link to your site.
Please provide a link to your site. Sincerely, Hella
biuro90
http://stkgsm.fcom.pl/
biuro90
biuro90 posted this 10 May 2018
It still does not work. Do you have a solution?
Support Team posted this 11 May 2018
Are you using the smooth scroll option in the theme? It may be the issue, try to switch it off and see if that helps.
Hi, Are you using the smooth scroll option in the theme? It may be the issue, try to switch it off and see if that helps. Sincerely, Hella
biuro90
biuro90 posted this 11 May 2018
http://stkgsm.fcom.pl/index.php/o-nas - is good but home http://stkgsm.fcom.pl/ still bad.
Hi, http://stkgsm.fcom.pl/index.php/o-nas - is good but home http://stkgsm.fcom.pl/ still bad.
biuro90
I found the cause. The section, columns, container blocks the keyboard navigation. When I delete all the elements, the navigation works correctly as on the subpages.
Please help!
I found the cause. The section, columns, container blocks the keyboard navigation. When I delete all the elements, the navigation works correctly as on the subpages. Please help!
Support Team posted this 18 May 2018
The scrolling is not working if Parallax option is enabled somewhere. Unfortunately the scrolling library used for this extension does not support keyboard scrolling.
Hi, The scrolling is not working if Parallax option is enabled somewhere. Unfortunately the scrolling library used for this extension does not support keyboard scrolling. Thank you, Olivia
