error message
arawolf
arawolf posted this 08 May 2018
I get a strange error message on the domain dkdecor.be see attachement.
6 Comments
Support Team posted this 08 May 2018
Looks like there is some plugin that loads its bootstrap.js file and a conflict arises. Did you please follow suggestions from this article?
https://answers.themler.io/articles/82654/bootstrap-conflicts
Hello, Looks like there is some plugin that loads its bootstrap.js file and a conflict arises. Did you please follow suggestions from this article? https://answers.themler.io/articles/82654/bootstrap-conflicts Sincerely, Nettie, BillionDigital Team
arawolf
sorry already done, but i can't find the plugin who's give the error
It can be helpful, also to clear cache after disabling/enabling a plugin and check if the error is still present.
Hello, It can be helpful, also to clear cache after disabling/enabling a plugin and check if the error is still present. Sincerely, Nettie, BillionDigital Team
arawolf
arawolf posted this 11 May 2018
done error message still appears
Support Team posted this 11 May 2018
Actually you can ignore that message if there are no issues visible on the site. If you close it in the application, it should not appear again.
Hi, Actually you can ignore that message if there are no issues visible on the site. If you close it in the application, it should not appear again. Sincerely, Hella
nayaraverma78
nayaraverma78 posted this 12 May 2018
thanks
thanks
