Accordion Menu HTML
Basics in Motion
Basics in Motion posted this 08 May 2018
I have recently moved from Artisteer (which I can not import because you do not do HTML) in which there was a vertical click to expand menu which worked wonderfully, this was perfect for my needs as I have many categories with sub sections, unfortunately I have now found that this is not available with HTML, I may be wrong?
I have tried to add HTML code and CSS Styling for an accordion menu but find i need to add Javascript , this is beyond my level of expertise so I am again frustrated and my project is at a standstill.
My question is accordion menu possible in HTML and if so can you do a walk through on this please.
If not can you please advise on javascript files.
Hi I have recently moved from Artisteer (which I can not import because you do not do HTML) in which there was a vertical click to expand menu which worked wonderfully, this was perfect for my needs as I have many categories with sub sections, unfortunately I have now found that this is not available with HTML, I may be wrong? I have tried to add HTML code and CSS Styling for an accordion menu but find i need to add Javascript , this is beyond my level of expertise so I am again frustrated and my project is at a standstill. My question is accordion menu possible in HTML and if so can you do a walk through on this please. If not can you please advise on javascript files. Thanks
Support Team posted this 10 May 2018
There is responsive style of the Vertical Menu which is similar to what you need:
Hi, There is responsive style of the Vertical Menu which is similar to what you need: !vmenu-resp.png! Thank you, Olivia
