Off Canvas Menu
matrix630307
matrix630307 posted this 09 May 2018
You write:
Note: Joomla Module Position control cannot be inserted into the Header and Footer areas as it is restricted by the Joomla module functionality.
What you mean in detail with this? - Can i activate this modul funcionality or can i not work with this in joomla?
Hi You write: Note: Joomla Module Position control cannot be inserted into the Header and Footer areas as it is restricted by the Joomla module functionality. What you mean in detail with this? - Can i activate this modul funcionality or can i not work with this in joomla?
Support Team posted this 09 May 2018
You cannot work with it in Joomla. The problem is that Joomla does not allow to load a module within a module and the menu is a module itself that includes Header and Footer containers. So unfortunately that is not possible and there is nothing we can do about that.
Hi, You cannot work with it in Joomla. The problem is that Joomla does not allow to load a module within a module and the menu is a module itself that includes Header and Footer containers. So unfortunately that is not possible and there is nothing we can do about that. Sincerely, Hella
matrix630307
ok - thank you for the answer. bad.... :(
Vitaliy WD
Vitaliy WD posted this 09 May 2018
Maybe you can separate menu from header/footer area or create offcanvas like a right/left sidebar (in future)? This will be more flexible solution if offcanvas can be like a right/left sidebar.
Support Team posted this 10 May 2018
The off-canvas sidebar is a Menu Bar with items. All these and responsive menu button are the menu control located inside menu module which is in specific joomla position. In case of Themler menu the off-canvas is the same menu as regular desktop menu but it has a little different styles. The location and HTML structure of the menu is the same.
Joomla position cannot be located inside joomla position. This is joomla restriction.
Hi, The off-canvas sidebar is a Menu Bar with items. All these and responsive menu button are the menu control located inside menu module which is in specific joomla position. In case of Themler menu the off-canvas is the same menu as regular desktop menu but it has a little different styles. The location and HTML structure of the menu is the same. Joomla position cannot be located inside joomla position. This is joomla restriction. Thank you, Olivia
denisp
denisp posted this 11 June 2019
with 1 year of delay.... anyway here is the solution.
For me it works even with a javascript
https://www.joomlashack.com/blog/joomla/modules-anywhere-menu/
Hello, with 1 year of delay.... anyway here is the solution. For me it works even with a javascript https://www.joomlashack.com/blog/joomla/modules-anywhere-menu/
