Video on the homepage
RITHO
RITHO posted this 10 May 2018
We've made this website: https://www.readytt.com and they would like to have a short video on the background on the homepage. Is this possible? Like this one: https://www.ktm.com/nl/
I hope it is possible and someone can help! Thanks for the response!
Greetings,
Marijn
Hello, We've made this website: https://www.readytt.com and they would like to have a short video on the background on the homepage. Is this possible? Like this one: https://www.ktm.com/nl/ I hope it is possible and someone can help! Thanks for the response! Greetings, Marijn
shaulhadar
shaulhadar posted this 11 May 2018
Hi Zierikzeker,
this is not possible with themler...
if you are using wordpress you can achieve it in a number of ways...
have a great day :)
Hi Zierikzeker, this is not possible with themler... if you are using wordpress you can achieve it in a number of ways... have a great day :)
Support Team posted this 11 May 2018
Why not) You can add a container with the absolute positioning and low z-index and insert the Video control into it. Then on the top you can add the menu and other controls with the higher z-index.
Hi, Why not) You can add a container with the absolute positioning and low z-index and insert the Video control into it. Then on the top you can add the menu and other controls with the higher z-index. Sincerely, Hella
mgarcia
mgarcia posted this 08 June 2018
Following other posts from this forum Ive put a background video in my homepage, you can see it in my sandbox.
http://demo1.nettix.com.pe/
Basically, Ive replaced a slider with an empty section. Inside I added a container that takes the whole page and inside i put a video control which calls my video (webm)
Currently I have some glitches that I need to fix with support people from themler, but seems looks good.
Hope this helps,
Martin
Greetings,
Marijn
Hello, Following other posts from this forum Ive put a background video in my homepage, you can see it in my sandbox. http://demo1.nettix.com.pe/ Basically, Ive replaced a slider with an empty section. Inside I added a container that takes the whole page and inside i put a video control which calls my video (webm) Currently I have some glitches that I need to fix with support people from themler, but seems looks good. Hope this helps, Martin > Hello, > > We've made this website: https://www.readytt.com and they would like to have a short video on the background on the homepage. Is this possible? Like this one: https://www.ktm.com/nl/ > > I hope it is possible and someone can help! Thanks for the response! > > Greetings, > Marijn
Support Team posted this 09 June 2018
Hi Martin,
We already answered you in the topic you created for video problems.
Hi Martin, We already answered you in the topic you created for video problems. Thank you, Olivia
