Animation Fails in Crop & Position of Image Why ?
Web IT Solutions LLP
Web IT Solutions LLP posted this 14 May 2018
Dear Sir,
In the Image Animations, if we set the Crop & Position the Animation failed. Why?
Is there any fixes for the same, long time back you said its an issue you will be fixing this soon but not yet done on your end. Why?
Suffian Ahmed
Dear Sir, In the Image Animations, if we set the Crop & Position the Animation failed. Why? Is there any fixes for the same, long time back you said its an issue you will be fixing this soon but not yet done on your end. Why? Regards Suffian Ahmed
Support Team posted this 17 May 2018
I'm not sure that the animation should work with the Scale and Crop extension as it renders the image as the background and the animation is applied to the element and not a background property. You can use animation with the image and set the desired image size using the Width and Height options instead of the Scale and Crop.
Hi, I'm not sure that the animation should work with the Scale and Crop extension as it renders the image as the background and the animation is applied to the element and not a background property. You can use animation with the image and set the desired image size using the Width and Height options instead of the Scale and Crop. Sincerely, Hella
