Mega Menu for Mobile Menu Button
DaveOzric
DaveOzric posted this 14 May 2018
Hello, can the mobile menu button open a mega menu? I am using a Menu Icon to conserve space. A mega menu would be helpful.
Hello, can the mobile menu button open a mega menu? I am using a Menu Icon to conserve space. A mega menu would be helpful. Thanks !Screenshot-113.jpg!
8 Comments
Support Team posted this 15 May 2018
There is no such possibility. For the mobile menu you can use only accordion menu of the off canvas menu options.
Hi, There is no such possibility. For the mobile menu you can use only accordion menu of the off canvas menu options. Sincerely, Hella
DaveOzric
DaveOzric posted this 15 May 2018
OK, thanks.
I thought of an idea how to make this work another way.
OK, thanks. I thought of an idea how to make this work another way. Thanks
Support Team posted this 18 May 2018
This will require a lot of script modifications.
Themler Team
Hi, This will require a lot of script modifications. Please let us know if you have any other questions. Thank you, Themler Team
DaveOzric
DaveOzric posted this 18 May 2018
No problem, I just created a whole new menu in Joomla using Alias menu items under a single menu item called Menu with a hamburger icon and set it to mega menu.
Works perfectly. It's not the perfect solution but exactly what I needed.
No problem, I just created a whole new menu in Joomla using Alias menu items under a single menu item called Menu with a hamburger icon and set it to mega menu. Works perfectly. It's not the perfect solution but exactly what I needed. Thanks
Nice to hear that you have found a solution. Feel free to contact us again.
Hi, Nice to hear that you have found a solution. Feel free to contact us again. Sincerely, Hella
DaveOzric
DaveOzric posted this 11 July 2018
Hello, on this site I had to switch to the slide or off canvas menu because of some strange behavior with the normal mobile menu.
Now when you open it in mobile menu mode the highlighted headings change to white as soon as you touch it. Can you tell me what is wrong?
This happens on the homepage menu on phones. https://monalcohr.com/
Hello, on this site I had to switch to the slide or off canvas menu because of some strange behavior with the normal mobile menu. Now when you open it in mobile menu mode the highlighted headings change to white as soon as you touch it. Can you tell me what is wrong? This happens on the homepage menu on phones. https://monalcohr.com/ Thank you
shaulhadar
shaulhadar posted this 12 July 2018
Hi Dave, i can see you have the bug that first time hover on the mega menu comes from the right, and than seconde hover works good.
I hope Themler team is working on fixing this....
Hi Dave, i can see you have the bug that first time hover on the mega menu comes from the right, and than seconde hover works good. I hope Themler team is working on fixing this....
DaveOzric
DaveOzric posted this 12 July 2018
I kind of thought the new menu might not be fully completed yet. At least it works on this site where the regular menu did not for some reason.
